Results 1 to 13 of 13
    Nov 2008
    harrisburg pa.
    02 vette vert
    3 and 4 channel help please
    do i have this correct that a 3 channel is abs and 4 channel is abs and tcs? and if i have no tcs and buy a 4 channel rear my abs works and the tcs capability of the rear is just not used?
    3 channel has the reluctor in the pumpkin..... 4 channel has the reluctors on the axles. What I'm not sure of is if the reluctors being on the axles will effect how it fits out there. I'm not sure if the backing plates are different or not. I want to say they're different but I'm not positive. Hopefully someone that knows 100% for sure will chime in.
    Nov 2008
    harrisburg pa.
    02 vette vert
    ok are you saying its not tcs, rather 2 front wheels and 1 rear axle, as opposed to 2 front and 2 rear wheels? at least i know that you can tell by looking at it. [ i forgot to ask that] or is the abs sensing moved out to the wheels with tcs when equiped with it. maybe im making this more difficult than it is.
    Feb 2006
    2002 WS6
    The abs with TCS equiped cars is monitored by the two wheel speed sensors mounted to the backing plates on the rear axles. Non TCS cars the ABS is monitored by the single sensor mounted to the pumpkin. The two systems as far as I know are not interchangable unless you swap BCMs as well.
    Nov 2008
    harrisburg pa.
    02 vette vert
    Quote Originally Posted by Orcus79 View Post
    i cant imagine there being any fitment issues, just if i put a 4 channel in a non tcs car i lose my rear abs, or the entire abs system. ?
    Feb 2006
    2002 WS6
    Fitment will be the same as far as the axel goes and you may have to redo your brake lines but I am not certain on that if the rear brakes on a non TSC car have a shared line or independent lines.
    You will lose all your ABS, which isn't bad thing as having only from ABS can be more dangerous.
    Nov 2008
    harrisburg pa.
    02 vette vert
    ill have to check the lines, probably tee's off at the rear end unless they run the lines the same on all of them. losing abs wouldnt be a bad thing, i still dont have the hang of just standing on the pedal and letting the car do the thinking anyway.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    so i have a 02 ws6 with abs and tcs,does that mean i have 4 channel abs?
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    more than likley
    11's "CLUB" SS SLP2's Avatar
    Silsbee, Tx
    Y2K Camero SS
    Quote Originally Posted by 02transamce View Post
    correct
    Johnny
    Y2K SS (SLP #239)
    Completly STOCK heads/bore/stroke/weight
    & NOTHING else ---is stock
    "NAW-NAW- just a Sunday goto meeting car, my best time is not in the 12's------- any more "
    ps: I am not soliticing work as I am retired
    >>>info on alignments
    http://www.jgruggles.com
    Member Rk ws6's Avatar
    Apr 2009
    Hagerstown, Maryland, United S
    2001 ws6
    i have a 2001 trans am with no tcs and im guessing its got abs lol so this is 3 channel...?
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    Quote Originally Posted by SS SLP2 View Post
    correct
    Johnny
    thank you,this info will help when i order my strange s60 rear axle.
    Nov 2008
    harrisburg pa.
    02 vette vert
    Quote Originally Posted by Rk ws6 View Post
    yes.
  1. 3 channel or 4 channel
    By 1badmonza in forum Drivetrain
    Last Post: 01-31-2011, 08:45 PM
  2. Help: Wacky 3 channel/4 channel issue
    By rel3rd in forum General Help
    Last Post: 01-03-2011, 05:00 PM
  3. Trade 4 channel 3.42 rear for 3 channel, and other
    By eddielb in forum Western Members
    Last Post: 11-03-2008, 06:24 PM
  4. 3 channel 3.42?
    By 96t/a in forum Drivetrain
    Last Post: 01-09-2008, 10:06 AM
  5. converting 3 channel abs to 4 channel
    By 02T/AWS6 in forum Drivetrain
    Last Post: 11-04-2006, 11:24 AM
