05-20-2007, 10:54 AM #1
Necessary to remove master cylinder to install struts?
Just curious if its necessary to remove the reservoir tank on the master cylinder to install a set of front struts as those dang t40 torx screws are pretty close under there. If not, whats the easiest method to get to them?
05-20-2007, 11:27 AM #2
yes. just remove the two 15mm nuts that attach it to the brake booster. then pull it off without removing the brake lines from it.
05-20-2007, 04:45 PM #3
duh, stupid me, i didn't even think about taking the whol f'n thing off, LOL. I was thinking man, drain that tank and risk getting fluid all over everything...ahahah, thanks for clearing that up, wow.
05-20-2007, 04:46 PM #4
no problem
Master Cylinder Swap/Install (Tick MC)
By tatertot91 in forum Manual TransmissionReplies: 6Last Post: 05-06-2018, 05:39 PM -
Master Cylinder install
By barryz in forum Manual TransmissionReplies: 2Last Post: 05-27-2011, 05:32 PM -
Question: How to remove clutch master cylinder
By sjloch in forum General HelpReplies: 2Last Post: 05-23-2009, 08:14 PM -
How hard to remove struts/springs at home?
By 5abivt in forum Suspension and HandlingReplies: 6Last Post: 05-16-2009, 05:57 PM -
which master cylinder should i get
By Z28_SS in forum Camaro / SSReplies: 0Last Post: 08-27-2007, 02:56 PM
