09-19-2011, 05:50 PM #1Senior Member
- Oct 2008
- Coral Springs, Fl
Master Cylinder Swap/Install (Tick MC)
Finally got around to swapping out my master, installed the Tick unit and love it. Same basic procedure to install the factory master minus adjustment.
These is just a guide, you're install may go in a slightly different order but it all goes together the same.
Here's a comparison of the new Tick unit to my old stock one. Notice the stock mounting bracket can be removed, take that into consideration during the swap. Also notice that the rod can be unscrewed from the Tick unit, removing it helps a lot during installation.
For reference the Clutch Master Cylinder is located below the Brake Master Cylinder and Brake Booster
I started off jacking up the drivers side of the car (always exercise safety and use jack stands and wheel chocks)
This will allow you to get underneath and disconnect the master cylinder from the slave located on the side of the transmission which you can see here
Push the plastic piece around the fitting and gently pull to disconnect it. Might get a bit of fluid so have a rag handy
Here is it removed
There is a heat shield which protects the line, this needs to be removed to allow you to pull the hose up and out of the car
Once that is done the reservoir can be removed, simply remove the fastener located on the side of it. If you have something like a syringe to remove the fluid do so, i left mine capped and didn't have a problem.
Here it is before and after i removed from its location after i fished it under the brake master cylinder
Now go inside the car and remove the panels underneath the steering wheel. It's held on by 2 Philips screws and 2 7mm screws
If your car is equipped with an electric hatch release unplug the harness going to the button
The plastic cover beneath that can now be removed. It is held on by plastic push in fasteners
Next get on your back and look underneath the console. The master cylinder rod attaches to the clutch pedal assembly over a pin and is held on by a small metal clip, simply remove the clip and slip the rod off. Tick recommends removing the spring in this picture with the installation of their unit, if you're installing another factory master leave it on
Next remove the two nuts from the firewall which hold the master cylinder in place (2 - 13mm)
Once those are removed you can tap the bracket through the firewall. Then from under the hood try your best to remove the master cylinder. It comes out along side the steering shaft. The harness running through the firewall runs very close to the master, i had to move it around a little in order to get the stock unit out.
Once that's out simply transfer the fluid reservoir from the stock unit to the tick unit (if you want to bleed the new master while it's out now is the time to do so). The Tick master goes in the same way the old one came out, tighter fit but same basic process. Remember it helps to unscrew the rod from the Tick MC during install. Really helps to have a buddy inside the car to get it lined up and bolted while you hold it in place. The Tick MC is held in place using 2 13mm bolts. Here is it in the car
Now the rod can be threaded back on the unit and the rod end can be slipped onto the pin on the clutch pedal. With the Tick MC the adjustment starts with the pedal barely off the floor so make sure when you install it the rod is at it's shortest setting. Remember to reinstall the small metal clip, otherwise it may come off down the road. Also face the grease fitting downward for future greasing. Here's it attached, notice the spring is now removed.
Place the Fluid Reservoir back in place and attach the line from the new MC to the slave under the car. You can lower the car back to the ground now
Hydraulics can now be bled, do your best to get all the air out of the system. You can do it the old fashion way and crawl under the car but the Tick speed bleeder line was installed during my clutch swap and it made bleeding it a breeze, highly recommend it. Just know it has to be installed with the transmission out of the car. Some people also like the MityVac method which was my last resort but the speed bleeder worked great for me.
Instructions for adjusting the MC come in the package but basically the pedal starts just off the floor and you start the car in neutral and try and get into 1st gear without forcing it. If it has trouble going in go under and lengthen the rod on the master by 1-2 turns and try again. Once it goes in smoothly test drive the car and if necessary adjust it if needed for high RPM shifting. Just make sure not to over adjust the rod, or you will risk internal damage.
From Tick's install sheet: "Correctly installed and bled, you will notice a pedal that is shorter and slightly more firm than the factory master cylinder."
100% true from my experience. Shifts are much faster and even driving the car around town is much nicer now. 1-2 shift is quick!
This is the second car I've installed this unit in if that says anything, I am extremely happy with it. If you can afford it, this is a definite upgrade you will notice!
09-19-2011, 08:22 PM #2
How long did that take? Great write up Alex. Definitely will be using this come winter.
09-20-2011, 04:52 AM #3Senior Member
- Oct 2008
- Coral Springs, Fl
Had a tting you were gonna ask that. Was tired up between this and another project my buddy was working on so I can't really say how long it took. start to finish I would put it at an hour and a half for the install depending on how the bleeding process takes. Also may take one or two rides to get it fully adjusted.
09-24-2011, 11:31 PM #4Senior Member
- Oct 2008
- Coral Springs, Fl
Just want to add something
Might run into this if you install a tick mc as i did, with the pedal being lower to the ground the switch that makes contact to the pedal and sees whether or not the clutch pedal is up or not may no longer operate like it should. Basically the car may think you're disengaging the clutch, therefore disabling the cruise control. The switch has threads and will need to be adjusted to work properly. I will show pics of what i mean later on
Just thought you all should know this
10-09-2011, 08:06 AM #5Senior Member
- Oct 2008
- Coral Springs, Fl
Finally got around to uploading pics
Here is the switch i had to adjust, as you can see in the pic the switch no longer makes contact with the clutch pedal.
All i did was unplug the switch harness, here's a pic of the plug. Used a small flat head screw driver and got it off
The switch has threads on it so once it was unplugged i simply spun it so that it made contact with the pedal assembly. Then i plugged switch back in and the job was done.
09-15-2013, 11:30 AM #6Junior Member
- Sep 2013
- albemarle nc
Great job writing this..ive been doing a master swap myself (01 SS) the problem im having is that the white plastic piece on the quick connect at the slave is cracked all over and wont release the steel braided line. Can i replace the plastic if it breaks off completly or will that require a new line?? My local auto parts house told me that the plastic part came with the slave but judging by the pics u put up it comes off.with the line itself! any advice for how to get it out of there?? Thanks
05-06-2018, 05:39 PM #7Junior Member
- Nov 2013
- Midwest
Black- 2001 WS6
I Installed the Tick Master Cylinder tonight and did it after reading this thread and watched the video by Blue Knight which comes up on youtube when you google "How to Master Cylinder Install and Drill Mod"
BOTH these resources were essential, and here are the things I observed while going through this process myself:
1) The "star washer" which is mentioned in passing in the video is a bear to get out the first time. It is sandwiched between the inner firewall and the clutch pedal mounting bracket. The way I got this off was to pry the clutch pedal mounting bracket forward off the lower bolt (there is only one star washer on the lower bolt and none on the upper bolt thankfully), then use a screwdriver to jam against one of the star-arms to get the thing to start turning and loosening. This cost me at least 30 extra minutes of trouble shooting and cursing.
2) Getting the old master cylinder out is challenging, you have to wiggle it, and wiggle the wire harness and pull the wire harness up and out of the bracket which mounts it to the side of the inner driver's side fender. I struggled getting the 2 bolts that hold the master cylinder in, to back out of the holes they protrude through on the firewall. These bolts are actually not 2 bolts but 1 "U" bolt, and I found when one started backing out the other one would catch on the firewall. Eventually it just came out after hammering it and then jammed a screwdriver in around the hole through which the master cylinder pokes through.
3) I highly recommend bleeding the new master cylinder before installing it into the car. I did this using a 20ml medical type syringe which I filled with brake fluid and squirted down the into the rubber reservoir hose (without the small reservoir tank connected), I did this at the same time as I held the "quick disconnect" end open by pressing my finger into the tip of it. Make sure you hold the "quick disconnect" end up high and try to hold the reservoir end lower than everything else, you want the air bubbles to "bubble up" and not get trapped somewhere. then I took a big bolt and forced it into the rubber reservoir hose to try and prevent fluid from leaking out.
4) I had the best luck removing the old clutch master cylinder and installing the new clutch master cylinder from the top of the engine. I physically climbed on top of the engine (from the passenger side using the battery as a step) and laid across the engine and reached down into where the clutch master cylinder goes.
5) Once I had the new Tick master cylinder in place and bolted to the firewall, BUT before I attached the "quick disconnect" back to the transmission I bled the system again. This time I had the quick disconnect hanging down loose below the car (lowest point on the system) and I held the rubber reservoir hose up (without the small reservoir tank connected). This time I filled my 20ml medical syringe HALF way with brake fluid, I would dribble some fluid into the rubber hose until it was topped up. Next I would attach the syringe to the hose and gently go back and forth on the syringe, first pulling back (often seeing bubbles bubble up) then push down pushing fluid into the system. I would often have to stop to disconnect the syringe and push any air out of it that I had drawn up from the system and then reconnect the syringe and repeat. I did this at least 5 or 6 times, maybe more. I noticed some of the brake fluid that started coming out had a dark/dirty color to it, despite being fresh fluid. I wonder if this is from assembly grease mixing with brake fluid in the system.
Disclaimer, I have not finished and gotten may car back on the road yet, but I anticipate that doing step # 3 and 5 will speed up the bleeding process. I don't have a Tick quick bleeder (well I do but I haven't pulled my transmission yet to install it), so I am hopping to find success using the mityvac method or going back to my syringe method once I connect everything together again. I think it is worth trying to bleed the new master cylinder before installing it, rather than installing it dry... my 2 cents. I'm a big fan of spending 10 minutes now to save me an hour later.
By johnfin in forum Firebird / WS6Replies: 30Last Post: 08-30-2012, 05:18 AM -
everyone should get a Tick master cylinder
By eatin mustangs in forum Manual TransmissionReplies: 7Last Post: 05-27-2012, 08:55 AM -
Just installed the tick master cylinder
By red00bird in forum Firebird / WS6Replies: 8Last Post: 08-11-2011, 02:41 PM -
Help: Tick Master Cylinder
By Hacked98WS6 in forum Manual TransmissionReplies: 2Last Post: 11-24-2010, 05:48 PM -
Question: Tick master cylinder?
By 97ramair in forum General HelpReplies: 4Last Post: 04-27-2010, 11:49 AM
