Results 1 to 3 of 3
Thread: Master Cylinder install
05-26-2011, 11:13 AM #1Member
- May 2006
- roosendaal , netherlands
white- 2000 transam ram air WS6
hey guys please check my pic i can't get the connection to the transmission
loose any tips would would help because i am trying to install a new master cilinder thanks greetings barry
05-26-2011, 05:15 PM #2
There is a plastic ring around it that you have to use to depress and open the connection. I have used two flat bladed screwdrivers to depress the plastic ring to open it before, but the best thing is to get the tool that opens it. Its at oreilly's and aluminum. I think its the orange one. It is split down the middle. Both the tool you need, and the plastic ring that is on there now. (OR missing)
05-27-2011, 05:32 PM #3Junior Member
- Jan 2011
- South Carolina
Black- 98 T/A
Open the bleeder and it will pop right on.
Master Cylinder Swap/Install (Tick MC)
By tatertot91 in forum Manual TransmissionReplies: 6Last Post: 05-06-2018, 05:39 PM -
01 Z28 T56 possible bad master cylinder ?
By 14camarolover in forum DrivetrainReplies: 5Last Post: 11-19-2014, 09:59 AM -
Question: Which master Cylinder?
By blackbird0230 in forum DrivetrainReplies: 23Last Post: 04-12-2013, 11:58 PM -
which master cylinder should i get
By Z28_SS in forum Camaro / SSReplies: 0Last Post: 08-27-2007, 02:56 PM -
Necessary to remove master cylinder to install struts?
By Zapper2003 in forum Suspension and HandlingReplies: 3Last Post: 05-20-2007, 04:46 PM
