Results 1 to 2 of 2
    Minnesota
    1987 Trans Am
    Master? No pedal pressure
    I was driving the other day, pushed in the clutch and gave it a little rev. My car pops out of gear and the pedal goes to the floor! Try as I might, I can't get the car into gear while it is running. I can shift into all of the gears while the car is off however. I have heard some bad things about the Centerforce dual friction clutch, but I have only put about 400 miles on my brand new clutch, master and slave.
    I have yet to bleed the system, which I will get done this week. My master is a GM which was prebled, do you still have to bleed the system when hooking up a brand new slave? Anyone have any tips or ideas?
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    BLEED IT!!! and also double check and make sure your shifter bolts are tightened down. Also goodluck with the CF I haven't heard of too many ppl having much luck with those. Not even me.
  1. Clutch pedal losing pressure?
    By redbird555 in forum Manual Transmission
    Last Post: 06-12-2012, 08:43 AM
  2. Question: Strange Engineering master cylinder pedal ratio
    By LT4_ever in forum Firebird / WS6
    Last Post: 03-29-2011, 10:37 AM
  3. No Pedal Pressure and Won't go into Gear!
    By RudyWS6 in forum Manual Transmission
    Last Post: 07-19-2010, 06:36 PM
  4. No pedal pressure after clutch install
    By chevyss1234 in forum Manual Transmission
    Last Post: 12-23-2009, 06:23 PM
  5. pedal wont return after master cylinder change
    By Ryans99LS1 in forum Drivetrain
    Last Post: 08-14-2009, 07:38 AM
