Results 1 to 1 of 1
03-29-2011, 10:37 AM #1Junior Member
- Grand Rapids, MI
puke Green- 1997 Firebird
Question: Strange Engineering master cylinder pedal ratio
Who's installed the Strange Engineering manual master cylinder? I'm an idiot and the instructions aren't clear enough for me.
Am I suppose to drill a hole on the brake pedal lever itself 1” above the existing booster rod / brake pedal connection point? There's a cotter-pin type connection where the rivet on the brake pedal connects to the brake cylinder conection rod. Do I measure 1" from center line of rivet and drill the hole there for the new connection point?
thanks guys!
strange clutch pedal issue
By Homer J in forum DrivetrainReplies: 2Last Post: 04-15-2011, 08:53 AM -
Question: Master cylinder question
By El Toro Loco in forum Manual TransmissionReplies: 3Last Post: 01-26-2011, 04:48 PM -
pedal wont return after master cylinder change
By Ryans99LS1 in forum DrivetrainReplies: 4Last Post: 08-14-2009, 07:38 AM -
Strange Engineering Rearend & Driveline Components
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 09-09-2008, 07:40 PM -
Master? No pedal pressure
By phoenix1987 in forum Manual TransmissionReplies: 1Last Post: 05-17-2007, 09:57 AM
