05-13-2007, 11:12 AM #1
Difference with LS1 intake vs ls6
My buddy has a 2002 Camaro SS! Did that come automatically with the ZO6 intake from the factory or is it the same unit (besides from the EGR fitting) as my 2000 Trans Am LS1 intake, and if so, what physical difference is there between the two?
05-13-2007, 11:42 AM #2
If it is an 02 its an LS6 intake which looks identical on the outside but is bigger and flows much better on the inside. Aside from the Lack of the EGR it is the same on the outside. On the bottom the LS6 is flat wheras the LS1 has a hump in the middle.
05-13-2007, 12:17 PM #3Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
Yeah the LS6 looks identical to the LS1 intake but has a larger plenum and slightly revised runners.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
05-13-2007, 12:29 PM #4
You will notice the difference when you switch!!! DO IT!!!
05-13-2007, 12:40 PM #5
Thanks, Ill do it first day I get off!! How much of a difference in power will it give me?
05-13-2007, 01:23 PM #6
I think it is around 10 horsepower or more! I am not positive though, It will surely wake the car up!
05-17-2007, 08:04 AM #7Junior Member
- Sep 2005
- Indiana
Light Pewter- 1999 Z/28
Always wondered why the LS6 flowed better, thanks for the info!
LS1 intake and TB make a difference on 5.3?
By lsgunner28 in forum External EngineReplies: 6Last Post: 04-08-2010, 07:03 AM -
F-body/Vette LS6 intake. Any difference?
By Cutlass in forum General HelpReplies: 15Last Post: 03-27-2009, 02:37 PM -
How to tell the difference between LS1 and LS6 intake
By Lawnman in forum External EngineReplies: 12Last Post: 03-17-2007, 03:35 PM -
Difference in Stock Ram Air intake and other aftermarket intake
By WS6-cobra killer in forum Firebird / WS6Replies: 5Last Post: 01-15-2007, 06:47 AM -
how do i tell the difference between an ls1 intake manifold or ls6
By josh110781 in forum External EngineReplies: 11Last Post: 10-19-2006, 01:54 PM
