Results 1 to 16 of 16
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    F-body/Vette LS6 intake. Any difference?
    Is there any difference in an LS6 intake from a Corvette/GTO than one from a F-body as far as hooking up things like the throttle body, PCV, Purge solenoid hose, brake booster hose,etc? I'm aware of the lack of egr and the need for a different coolant bypass pipe/plugs.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    nope all the same..
    Madison, WI
    2001 Silverado Z71
    Alright! Cool.
    What do you think of my this little upgrade plan I have going?
    LS6 intake, Shaner S3 throttle body and LSXtune.com mail order tune to delete EGR, AIR, Rear O2s, and CAGS, plus whatever other little things they do.
    Its probablly only about 15- 20 RWHP gain but I also lose a little emission weight and clutter.
    same combo I run....you'll like that shaner tb. He does really nice work. Frost will be able to hook your tune up other than just deleting that stuff too.
    Madison, WI
    2001 Silverado Z71
    should I get the satin or polished TB?
    I got the polished version....absolutely beautiful.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    There was a test done a little while ago that found that the F-Body LS6 Intake actually flowed slightly better than the Corvette/GTO LS6 Intake.
    Just thought I throw that out.
    Shepherd, Michigan
    98' trans am
    Alright! Cool.
    nice..are you a manual? if your a auto frost will hook you up even more with some of the trans tuning that while wont net you more power(dyno power) it will lead to better times for sure
    Shepherd, Michigan
    98' trans am
    yeah you would..wouldn't you
    Laurel, Maryland
    2000 Grand Prix GTP
    Madison, WI
    2001 Silverado Z71
    Yeah M6 here. So I'll just be getting the Skip Shift deleted.
    Madison, WI
    2001 Silverado Z71
    Well I got everything done except the Shaner S3 throttle body. I paid for it but haven't seen it yet. Not sure what the hold up is.
    I bought a "ZO6 Corvette LS6 Intake just removed from a 2001 Corvette" off of Ebay. Ended up the part number was for a F-body LS6 intake (stupid inaccurate Ebay listings). I had to pull a small chunk of metal out of it (a little upsetting) and clean it up. Yikes, if that metal fell into my engine, that would be bad. I ended up grinding the ridges off the bottom of the intake to fit over my existing coolant lines. I still had to kinda squish it down over them so I might just get the correct line/plug kit for it.
    shaner does excellent work but he's slow as hell. It took my TB forever and a day to get here. It was worth the wait though.
    There's no sense in getting the correct parts now since you've already butchered your $300 intake and half assed it.
    Laurel, Maryland
    2000 Grand Prix GTP
    It least it was a LS6, rather than a LS1 advertised as a LS6.
    Madison, WI
    2001 Silverado Z71
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    Should Gain 70-80WHP right?
    Sounds like your headed in the right direction so far
  1. For Sale: Ls1 intake, LS1 F-body and LS1 Vette manifolds FS
    By OutToWinPAHC in forum Parts For Sale / Trade
    Last Post: 01-08-2010, 08:09 PM
  2. engine difference between ws6 and vette
    By big hammer in forum General Help
    Last Post: 11-18-2007, 03:09 PM
  3. Replies: 28
    Last Post: 05-04-2007, 09:27 PM
  4. Difference in Stock Ram Air intake and other aftermarket intake
    By WS6-cobra killer in forum Firebird / WS6
    Last Post: 01-15-2007, 07:47 AM
  5. Replies: 25
    Last Post: 04-13-2006, 06:18 AM
