    baltimore md
    99 ws6
    Dead spot or miss. help
    Hey guys i have a 99 ws6 trans am. it has either a miss or a dead spot mostly around 2400-2500 rpms when i put a load on the motor like hit the gas about half way maybe alittle more. also it seems to do it worse when its cold. any ideas? i already did plugs and wires
    Retired Outlaw Sum Bitch
    Did you change the fuel filter?
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    You haven't noticed your temp guage moving more than normal? If so check your temp sending unit to make sure the wire is connected. I had that problem on my SS it would cut out when it got loose. It would even kick off the cruise on it. Just an idea. Probably like Sarge said a fuel filter.
    San Diego
    2002 T/A
    Deap spot on TPS sensor. Try checking it with a scanner. Or graphing multimeter if you got one.
  1. Miss Wisconsin = Miss America! Score one for the Midwest lol
    By blackSS01 in forum Almost Anything Goes
    Last Post: 01-21-2012, 08:05 PM
  2. Need help with dead spot
    By 00ss6spd in forum General Help
    Last Post: 01-13-2010, 04:46 AM
  3. Help: dead spot in steering
    By Pony_Eater in forum Suspension and Handling
    Last Post: 04-08-2009, 01:24 PM
  4. Dead spot or miss help
    By onebadassws6 in forum General Help
    Last Post: 05-02-2007, 11:21 AM
  5. Dead Spot from Air/Fuel mixture? Need Help Please
    By 99m6t/a in forum External Engine
    Last Post: 05-22-2006, 09:01 PM
