Results 1 to 20 of 23
    lexington,va
    blue
    2000 chevy camaro ss
    Need help with dead spot
    Just bought an 00 ss. 6speed, it has a dead spot and stumbles from 2200 up and doesn't run like it should. The SES light came on and said it was rear oxyen sensors so I jutted them and still no change. Also replaced all 4 oxy sensors and air filter. Im lost as to what makes it stumble and run like crap from 2200 up. Also I replaced fuel filter. Anyone know of common problems?
    Nov 2009
    NOVA
    2002 C5 - M6 - Blue
    2000 Z28 - A4 - Pewter
    I take it, it does this in any and all gears. Does it do it while only in gear and under load? Have you tried it taking it up to say 4k in 1st gear and letting it slow itself back down? How does it react?
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    check plugs?
    lexington,va
    blue
    It does it in any gear, its complety controlled by the rpm. It does it sitting still in neutral. I checked the plugs but all looked good.
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    Get some MAF cleaner from a parts store and give you a MAF a good cleaning.
    lexington,va
    blue
    I also tried the maf cleaner but I forgot to mention it.
    Indianapolis
    2000 WS6 6spd Hooker LT
    Try cleaning your MAF. People here have done this to fix just what you're describing. Autoparts stores sell specific Mass Air Flow spray, just be careful to not touch the wires, they can break. Could be a fuel pump going bad also.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Also try fuel system cleaner. I have used Seafoam and I am happy.
    Possibly 02 sensors(fronts) or you need new plugs/wires, since you say you have already cleaned the MAF, changed fuel filter, and air filter.
    lexington,va
    blue
    When I did 02 sensors I did all four. Thats why this things confusing me, I figure if it were plugs or wires it'd do it off idle also
    Nov 2009
    NOVA
    2002 C5 - M6 - Blue
    Sell it to me and I'll deal with the headaches
    sounds like you've done all the initial things.....I'd look at plugs/wires and injectors next. know anyone with a scan tool that you could borrow to see what cylinders are missing? That would help you immensely.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Sounds like plugs to me. Change them, NGK TR55's are pretty cheap. While your there, its worth it to replace the wires. I run MSD's and have no complaint. Having a GOOD scanner would help alot, but change those plugs/wires and see where your standing.
    Build in progress...
    Member crossbredfoxbody's Avatar
    First In Flight
    83 mustang coupe
    Have you checked your tps reading at wot, partial and closed
    Florida
    1999 TA WS.6
    Quote Originally Posted by crossbredfoxbody View Post
    Doubt it If he didn't mention having a scanner in the first post, I doubt it.
    OP, finding a good scanner (buddies maybe?) will help a ton, if the plugs and wires don't solve it. Whats your fuel PSI? Hook up a mechanical gauge to the test rail (drivers side) and check at idle, off idle, and WOT. It should be 58 PSI at idle, and drop slightly at WOT.
    lexington,va
    blue
    I checked the tps, anyone know where I can get a gauge to check psi with.
    First In Flight
    83 mustang coupe
    Cornwell for like 50 bucks or loner tools at advance,autozone,oreillys
    I bought one at advanced auto or autozone ( forget which one) for ~$20
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Or you might have a weak coil or two. How many miles are on it?
    Indianapolis
    ^^^Could be, but that will usually set a misfire code, and he hasn't reported any of those yet. Need to rule out fuel pressure next....
  1. Help: dead spot in steering
    By Pony_Eater in forum Suspension and Handling
    Last Post: 04-08-2009, 01:24 PM
  2. Hmm... well I think this is the spot for this...
    By B34M3R in forum Multimedia Section
    Last Post: 11-08-2008, 08:42 PM
  3. Dead spot or miss. help
    By onebadassws6 in forum General Help
    Last Post: 05-03-2007, 06:25 PM
  4. Dead spot or miss help
    Last Post: 05-02-2007, 11:21 AM
  5. Dead Spot from Air/Fuel mixture? Need Help Please
    By 99m6t/a in forum External Engine
    Last Post: 05-22-2006, 09:01 PM
