Results 1 to 14 of 14
Thread: dead spot in steering
03-15-2009, 10:29 PM #1
When i turn left and then go straight into a right turn at the top of the turn the wheel seems to skip like there is a dead spot in the steering. Any ideas to what it is?
03-16-2009, 08:22 PM #2
cmon guys anyone got anything?
03-16-2009, 10:54 PM #3Impounded
- Oct 2007
- Beaver Dam KY
Check fluid? Tie Rods? Pump is dying?
03-16-2009, 11:08 PM #4
What could be wrong with the tie rods? I just replaced the rack and pinion/pump/tie rods 2 weeks ago.
03-16-2009, 11:17 PM #5Impounded
- Oct 2007
- Beaver Dam KY
03-26-2009, 11:35 PM #6
Do you have long tube headers? if so check the clearance at the top joint of the coupler shaft... or what ever it's called. the one that ties the steering column to the rack.
03-27-2009, 11:11 AM #7
No i dont have LT's. but when i am just sitting there not rolling i can move the steering wheel about 2-3 inchs to the left or right without the wheels moving. I dont like it lol
03-27-2009, 11:27 AM #8Impounded
- Oct 2007
- Beaver Dam KY
03-27-2009, 04:22 PM #9
ok i got play in my steering how do i fix it? lol
03-28-2009, 09:14 AM #10
go back and tighten the bolt that holds the steering shaft to the rack. when i swapped mine out, i thought i had it tight enough. i had about 2" of play and thought it was the replacement rack i put in. went back and really cranked down on that bolt and the play went away.
03-28-2009, 06:37 PM #11
which bolt exactly? do you mean the 10mm one that is reachable through the top of the engine bay or the one right on top of the rack underneath the car?
03-29-2009, 05:43 AM #12
03-29-2009, 06:58 PM #13
lol ok i was just wondering cuz im at school now and if its the one on top i can get to it here but if its not i gotta wait till i get home
04-08-2009, 01:24 PM #14
ok i got the play out of my steeering(it was those two bolts that were loose) but i still have the skipping problem. when going from a left turn into right turn or vis versa it feels like it pops or skips a little bit any more ideas? if anyone in the SD area wants to look at it im down
Need help with dead spot
By 00ss6spd in forum General HelpReplies: 22Last Post: 01-13-2010, 04:46 AM -
Hmm... well I think this is the spot for this...
By B34M3R in forum Multimedia SectionReplies: 0Last Post: 11-08-2008, 08:42 PM -
Dead spot or miss. help
By onebadassws6 in forum General HelpReplies: 3Last Post: 05-03-2007, 06:25 PM -
Dead spot or miss help
By onebadassws6 in forum General HelpReplies: 0Last Post: 05-02-2007, 11:21 AM -
Dead Spot from Air/Fuel mixture? Need Help Please
By 99m6t/a in forum External EngineReplies: 1Last Post: 05-22-2006, 09:01 PM
