Results 1 to 11 of 11
    Junior Member garrity455's Avatar
    Chicago
    black & gold
    2000 WS6 TA
    Change Caliper Bleed All Brakes?
    Hi guys. I was wondering. If I change one caliper (front passenger), that has a stuck piston. Can I get away with just bleeding that particular brake. Or will I have to bleed all of the lines if I change the caliper?
    Any advice on the caliper change?
    Thanks.
    11 Second Club 11.34 bigboykilroy's Avatar
    Aug 2006
    Streetsboro, Ohio
    1998 Firebird Trans AM
    you should be ok just bleeding that one side as long as you swapped out the new one fast, but to be safe i would at least bleed the front (Left and Right) since they are tied together. the rear is fine.
    I would bleed both of the front ones to be safe.
    Painted manta stripe
    San Diego
    2002 T/A
    Why risk it? Bleed all four. My .02
    Chicago
    black & gold
    2000 WS6 TA
    Thanks guys. It was late after work, and didn't feel like taking all of the tires off of the car. So I just did the front two. But all seems well. Thanks for the input.
    Garrity
    Make sure you bleed the ABS system first then go to the calipers.
    I believe the prefered method is ABS system first followed by passenger front then drivers front followed by passenger rear and finally driver side rear.
    Now would be the perfect time to upgrade the brake fluid as well!
    At the very least use a new bottle of brake fluid.
    Chicago
    black & gold
    2000 WS6 TA
    I didn't know about bleeding the ABS system. Where does it have bleeders at? I just bleed each caliper. The line was only open for about 5 seconds, while I switched Calipers in my hand. Hopefully I won't have any problems.
    Thanks,
    mike
    There is the same size bleader screw just under the ABS system located on the drivers side of the engine bay. If you feel some softness in your brake pedel you could have some air in the system and you might have to redo the procedure.
    San Diego
    2002 T/A
    Quote Originally Posted by garrity455 View Post
    Famous Last Words.
    Chicago
    black & gold
    2000 WS6 TA
    Ok thats cool, I will keep that in mind. Thanks for the info.
    Chicago
    black & gold
    2000 WS6 TA
    The banana rocks.
  1. Question: wanting to change brakes
    By Valor X in forum General Help
    Last Post: 08-27-2012, 02:35 AM
  2. New Brakes/Rotors/Caliper
    By Smkn_TA in forum Suspension and Handling
    Last Post: 08-28-2007, 08:40 AM
  3. Can I bleed my brakes without taking the wheel off ?
    By Speedy_Gonzales in forum General Help
    Last Post: 08-27-2007, 03:35 PM
  4. problem getting caliper loose to change pads
    Last Post: 08-11-2007, 07:08 PM
  5. How do you bleed brakes?
    By wicked illusions in forum General Help
    Last Post: 03-19-2006, 07:53 AM
