    Georgia
    2014 Camaro 1LS
    Can I bleed my brakes without taking the wheel off ?
    this is my first time bleeding the brakes also where is the bleeder valve I turn to bleed them ?
    Georgia
    2014 Camaro 1LS
    Can I bleed my brakes with the wheel on ??
    also this is my first time bleeding the brakes on my ss, where is bleeder valve located that I have to turn to bleed the brakes ?
    nj
    90 Mustang 5.0
    its located directly on your calipers. its probably either an 8mm or 10mm. Bleed as follows: Right rear, left rear, right front, left front. Get a pedal man that can follow directions. get the pedal high and hard, then direct the pedalman to hold the brake pedal, then open the bleeder, watch the stream, if the stream is steady and theres no bubbles that caliper is good, close the bleeder and make sure the pedal man still has his foot to the floor. when the bleed is closed tell him to pump it again and go onto the next caliper. unless you removed a caliper, or you have a really mushy pedal there really is no need to bleed your brakes jus for the hell of it.
    You have to take the wheels off to bleed them. The bleeder valve is on the top of the caliper, towards the back side of it. You will need a 10mm wrench.
    Painted manta stripe
    Georgia
    2014 Camaro 1LS
    got it done.......thanks for the post, need to put a check in the mail for all your help lol
    Georgia
    2014 Camaro 1LS
    got it done......I had changed the pads a few weeks ago and the pedal had got mushy
  1. Four-Wheel Disc Brakes for a 1965 Pontiac GTO
    Last Post: 06-17-2015, 07:00 AM
  2. How to bleed the air
    By karpetcm in forum General Help
    Last Post: 01-19-2009, 04:04 PM
  3. Change Caliper Bleed All Brakes?
    By garrity455 in forum Suspension and Handling
    Last Post: 05-01-2007, 10:03 AM
  4. Replies: 2
    Last Post: 08-16-2006, 06:17 PM
  5. How do you bleed brakes?
    By wicked illusions in forum General Help
    Last Post: 03-19-2006, 07:53 AM
