Results 1 to 19 of 19
Thread: Belt squeel
04-19-2007, 07:50 PM #1
Belt squeel
My belt has begun to squeel rather badly, its horribly annoying, and tis worse when its wet out. The belts basically brand new, is it too tight, to loose, or what?
04-19-2007, 07:52 PM #2!!!!!!!!!!!!!!!!!!!!!!!!!
- Jan 2007
- Rockford, IL
Silver- 2000 Camaro SS
my gfs eclipse has the exact same problem. replaced the belt and problem still occurred... tightening the belt didnt help. neither did loosening...
just lettin u know ur not the only one out there w/ that problem, and also now im subscribed cuz id also like to know the answer to the question
04-19-2007, 07:57 PM #3
mine is doing this too i heard that after awhile some of the belts get a glaze on them and make a squeeling noise this is what i heard from a mechanic
04-19-2007, 09:03 PM #4
i fuckin hate it... it sounds like a 1980's civic now... hard to be impressed with a musclecar that whines like the motors about to fall out.
04-20-2007, 08:20 PM #5
Usually, in most cases, the belt whine is from having too much slack in it. Try and tighten it up with the idler pulley, or adjusting an accessory pulley. Older vehicles, you had to slide an accessory away from the others to tighten the belt, but with the newer vehicles, its usually in the idler pulley.
04-20-2007, 08:43 PM #6M6 King
- Mar 2006
- WI
- Blog Entries
- 1
Mine squealed like that until I put my new goodyear gator back belts on. I cleaned all the pulleys really good and haven't had any squeal come back. Did you spin your pulleys to make sure something else isn't wrong?
04-21-2007, 12:58 PM #7Junior Member
- Jul 2006
- Newport KY
Red- 1995 Chevy Camaro
Turn up the radio
04-21-2007, 07:15 PM #8
i cant really hear it when im listenin to music or over my exhuast at speed, but outside the car its louuuud
04-22-2007, 09:19 AM #9!!!!!!!!!!!!!!!!!!!!!!!!!
- Jan 2007
- Rockford, IL
yea if im right and u have the same problem as my gf, it is an obnoxiously loud and annoying sound. hearing it outside of the car is horrible, it sounds almost like tires squealing
04-22-2007, 10:57 AM #10
yea thats it! it goes away sometimes, like some days it wont even happen at all, other days it sounds like a hollywood sound engineers recording for a car thats about to explode
04-22-2007, 12:50 PM #11
just had this issue on my truck and my money would have to be on the tensioner. If the car has its fair share of miles on it, the tensioner may have just worn out enough to loosen the belt to make it squeal.
04-24-2007, 10:18 AM #12Senior Member
- Feb 2006
- Orange County, NY
definetly take a look at the tensioner. if the spring is worn it wont put enough tension on the belt. also could be the bearing on the tensioner.
04-24-2007, 05:37 PM #13
Its completly gone away, and its been 15-20 degrees warmer here this week then it has been... coincidence?
04-24-2007, 06:26 PM #14ArtistFormerlyKnownAsMac
- Apr 2006
- Indianapolis, IN
All Black- 83, 87, 02 All WS6 T/As
I have noticed mine squeels.. form something when I am REALLY on it.. almost like a pulley is going... and it has gotten worse.. but only notice it at WOT.....
-Geno
1983 Black WS6 "WindCharger"
1987 Black WS6 "WS87"
Sold the other four f-bodies
04-24-2007, 09:06 PM #15
mines worse at idle, seems to get lower as the rpm increases, but since the weathers gotten warm i havent noticed it at all! i'm guessin the rubber is softer when its warm so wont squeel anymore? idk...
04-24-2007, 09:19 PM #16!!!!!!!!!!!!!!!!!!!!!!!!!
- Jan 2007
- Rockford, IL
hmm. my gfs squeals at random times, mostly when at idle tho. it doesnt seem to fade at all at higher rpms or anything, but if she floors it to redline it will stop, as if something was knocked back in place cuz it wont do it again till another random time.
sound familiar at all?
04-25-2007, 06:19 AM #17
yea thats kind how it was... but now i havent heard from it in days... hopefully it wont come back in the fall
04-25-2007, 01:44 PM #18!!!!!!!!!!!!!!!!!!!!!!!!!
- Jan 2007
- Rockford, IL
sorry i couldnt offer any suggestions. she never fixed her car, it just kind of went away as it got warmer also. so i guess if u can do some research now, u will know what to do when it gets cold again (or if it just starts up randomly)
just wanted to relate to u, and see if it was a similar problem, so that if me and my gf figure out her problem i CAN help u out
05-04-2007, 09:08 PM #19Junior Member
- May 2007
- Wyoming
black with flames and #7- 2007
My 95 Z28's belt would slip everytime my car shifted, people thought I had a turbo. Maybe some belt dressing?
strange squeel when turning
By 98TransAmWs-6 in forum General HelpReplies: 8Last Post: 05-07-2010, 03:56 PM -
engine squeel
By jstites in forum LT1Replies: 3Last Post: 04-11-2010, 04:05 AM -
Annoying squeel after washing engine bay
By ss~zoso~ss in forum General HelpReplies: 18Last Post: 05-13-2009, 11:31 AM -
Belt squeel?
By red99ws6 in forum General HelpReplies: 12Last Post: 11-07-2008, 01:00 PM -
Squeel Piggy!!!!!!!
By Blitzed in forum Almost Anything GoesReplies: 11Last Post: 10-01-2007, 04:52 PM
