Results 1 to 19 of 19
05-10-2009, 04:23 PM #1
Annoying squeel after washing engine bay
So as the title says, I washed my engine bay as i normally do, and let it sit for a bit while i washed the car, upon startup the (what sounds to be the belt) started to squeal...
after 75 or so miles of driving the squealing persists, I had even sprayed belt dressing on the belt when it was running, and still nothing, when i sprayed the belt it made the squealing worse when i was spraying then after it was back to the regular squeal
im perplexed, and pissed off, its a noticeable squeal while driving and at idle
any ideas?
05-10-2009, 04:28 PM #2Impounded
- Oct 2007
- Beaver Dam KY
Take off the belts and spin each pulley/idler by hand. Mine does the same thing and it wont go away till I WD40 everything then i have to wipe off the mess
05-10-2009, 04:34 PM #3
yea idk if its a pulley / idler cuz of the reaction when i sprayed the dressing on the belt and the change in noise,
but i guess i'll WD all the pulleys and see wat happens,
idk how the belt could be squealing so much, it only has like 10k on it
05-10-2009, 04:35 PM #4Impounded
- Oct 2007
- Beaver Dam KY
05-10-2009, 04:40 PM #5
right right right, thats what i meant
i'll try it tmro
still open to other thoughts tho, there can only be so many possibilities
05-10-2009, 04:46 PM #6Impounded
- Oct 2007
- Beaver Dam KY
05-10-2009, 05:53 PM #7
does your power steering or anything up front leak? May have just washed something onto the belt or pulley that's taking some time to burn off.
05-10-2009, 05:59 PM #8Senior Member
- May 2009
- Toronto
SOM- 2002 SS
What did you use to clean the engine compartment? I just did this with simple green and cleaned my engine bay but if ANY gets on the belt it will remove the moisture from the belt which = dry and soon to crack belts. WHen it loses its lubricitity it will squeal.
My belt was perfect and after I washed it it squeals like hell now. I'll be changing it this week.
05-10-2009, 06:16 PM #9
i used simple green, but i dont see that ruining a belt cuz it didnt directly get sprayed on it, and by the time any of it may have reached the belt it had to have been VERY diluted
i even put belt dressing on the belts, idk if the belt is the problem or if its the pulley(s)
i'll try to mess with it tomorrow...
05-10-2009, 08:15 PM #10Senior Member
- May 2009
- Toronto
SOM- 2002 SS
I have a post on the 2nd page with pics of my simple green engine cleaning. My belt now squeals I did this just a few days ago. It squealed the moment I fired it after the cleaning. Like you, I put belt dressing on it and it shut up for a few seconds and just came back even louder. Coincidence?
05-11-2009, 02:37 AM #11
05-11-2009, 07:46 AM #12
I change the belts after I clean the engine with simple green. I plan the the two together.
05-11-2009, 02:56 PM #13Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Mine stopped squealing. But my alternator died now
05-11-2009, 05:02 PM #14
still squealing here
i squirted WD on the top left idler pulley, i dont see it being possible to squirt any of the others ..
05-11-2009, 08:06 PM #15Impounded
- Oct 2007
- Beaver Dam KY
05-12-2009, 12:58 PM #16
negative, gotta find time to do it, its pretty easy? or wat?
05-12-2009, 05:17 PM #17Senior Member
- May 2009
- Toronto
SOM- 2002 SS
EXTREMELY EASY. You wont believe how easy it is. I just removed the intake duct from the throttle body and the filter housing. You will see the belt in plain sight. use a 15 to turn the tensioner and pull the belt off the alternator. Pull it out. the diagram is honestly so very simple. reroute the belt leaving the alt last and then just turn the tensioner and push it on the alt pulley. Honestly I had to get it off to change the alternator I'm not even worried that I should have changed the belt while I was at it. it's a 2 minute job.
05-12-2009, 08:25 PM #18Impounded
- Oct 2007
- Beaver Dam KY
05-13-2009, 11:31 AM #19
good to know guys, so you just turn the 15mm bolt and that moves the tensioner, it doesnt loosen it, it's spring loaded right?
i'll give this a shot at some point!
i'll post up afterwards
Washing an engine
By 024mula in forum Showcar and DetailingReplies: 16Last Post: 01-28-2025, 05:46 AM -
Knock Sensors toast after engine washing??
By jfl330 in forum General HelpReplies: 21Last Post: 06-07-2011, 04:59 AM -
engine squeel
By jstites in forum LT1Replies: 3Last Post: 04-11-2010, 04:05 AM -
Belt squeel?
By red99ws6 in forum General HelpReplies: 12Last Post: 11-07-2008, 01:00 PM -
annoying engine noise
By emotionalpiracy in forum General HelpReplies: 3Last Post: 05-16-2008, 12:05 PM
