Results 1 to 17 of 17
Thread: Washing an engine
09-10-2016, 06:00 AM #1
Washing an engine
With an LS1 engine there's a lot of wires and stuff take should not get wet, so what this the correct way of washing an LS1 engine? (a video would be nice).
09-18-2016, 10:16 AM #2
I should have video'd myself as I just did this. Should be good for a year now
. Just avoid the battery, and the intake manifold. Everything else can be sprayed wet. On a cold block, in my garage, I used an APC ( all purpose cleaner ) not a engine block degreaser as painted and plastics may suffer. Agitate surfaces with a soft bristle brush and rinse it in a bucket of clear water. Then rinse the under-hood and the places you cleaned. I blow dryed the engine bay with my stihl leaf blower, focused real good on the intake manifold as water puddles formed around the injectors, let it sit the rest of the day hood up in the garage. After dinner I went out and hit it all up with a trim dressing to get the plastics looking slick and new.
Next day car started up no issues or aromas at all.2000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
09-18-2016, 04:47 PM #3
Thanks!
2002 Firebird Formula - 5.7 Liter - "Last of the Breed"
04-02-2019, 06:52 PM #4Junior Member
- Apr 2012
- South East Georgia
BLACK- 1998 WS6, ASC BUILD #206
I just cleaned my engine bay last week for the first time in years.
First I need to say I have no leaks of any kind so I didn't have that issue to deal with.
Just years of normal road and rain build up.
I did start with a light cleaning using a pressure washer. I seriously didn't like the idea but kept it
back enough to not mess things up. Then I took a bucket with soapy water and bit the bullet.
Hand washed everything I could get to. Don't ask how many cuts and scrapes I have on both hands and arms. (grin)
I would spray away soap and soil every few minutes. Once it all looked clean I used my air compressor to get all the water I could manage out, off OR away from everything. It worked well. No issues with cranking at all.
This took me ALL DAY to do. Well, almost. Started about 10 am until dark thirty.
The next day I used back to black on all hoses, wires, plastic etc I could get to and spray waxed all else under the hood. That took almost another day. I would hate to do this for a living. However, all the time and labor was / is well worth it.
It looks great.
Good luck with yours.
12-18-2019, 04:08 AM #5Junior Member
- Dec 2019
- Phoenix, Arizona, USA
Just had my engine washed in a local car wash. I just noticed that the guy who did the cleaning applied an oil that smelled like kerosene on the surface of the engine.
12-18-2019, 05:52 AM #6Spaz is My Mentor
he trying to burn it down?
01-04-2020, 10:41 AM #7Senior Member
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
My engine bay gets diluted Spray Nine, or the sort, and the rinses withal a spray bottle of water.
The engine gets brake cleaner in really dirty, or hard to reach spots.
No more hoses/pressure cleanings after I drowned out my knock sensors just before Carlisle 2017.SLP Air Lid/Smooth Bellows
L76 6.0L block, PRC Ported 243 heads, Texas Speed 228R cam.
Elite Engineering PCV Oil Catch Can
SLP Smooth Air Lid and Smooth Belows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Strano Master Cylinder/Firewall brace
dynoed @ 472 rwhp
Weight reduction via removal of dead mice
06-08-2020, 07:00 AM #8Junior Member
- May 2020
Haven't tried washing my car's engine. I'm too afraid that something that will go wrong.
07-02-2020, 08:12 AM #9Junior Member
- Jul 2020
My brother in law used kerosene to clean the engine. It scared me as hell. Lol.
07-30-2020, 01:08 AM #10Junior Member
- Mar 2015
- Fl
I use CG Orange Degreaser diluted at 5:1 ratio.
08-02-2020, 07:58 AM #11
I wash the engine bays in all of our cars. Quick spray down with Simple Green and then a careful wash with a soaped up mitt or soft bristle brush followed by a low pressure rinse. I then towel dry and use the air compressor to blow dry everything, catching the spray with the towel. Once hand dry I then immediately start the engine and allow things to come up to temp and evaporate out the remaining water. Been doing it this way forever and have had zero issues.
08-02-2020, 06:56 PM #12Senior Member
- Sep 2010
- Bel Air, Maryland
I washed my engine bay once, ended up having to replace the knock sensors and wiring harness form them.
I know clean my engine bay, using a spray bottle to do the wetting/rinsing now.
08-13-2020, 06:36 PM #13Junior Member
- Dec 2017
- Hinesville, GA
09-22-2020, 06:28 AM #14Junior Member
- Dec 2019
10-12-2020, 07:00 PM #15Junior Member
- Jan 2020
- Florida
Red- 2003 GMC Sierra
11-08-2020, 05:53 PM #16
Just want to add to this thread.
There are 2 ways of cleaning your engine. Engine wash - First one is the low pressure wash, basically you have to cover the important electrical parts with plastic to protect it from water. Usually, it is the alternator, computer box, ignition coil and distributor (for old cars). You need an engine degreaser (diluted 60/40), a detailing brush or just tooth brush, and microfiber/terry towel. Just spray degreaser and agitate the parts, you can start from the outer part and one section at a time. The rinse with power wash or just with your hose will do. You don't have to do this if you are not confident. This is a faster way but risky.
The second is Engine Detail, not to use the power wash, you just need to have a blower, degreaser, microfiber/terry towel, detailing/toothbrush and a water bucket to rinse towel every now and then. Use the blower to remove dust, spray degreaser and start one section at a time. wipe with damp towel and blow dry. Just continue the same process until you complete it. This is safer way and outcome is decent for a DIYer.
You can apply plastic/rubber conditioner/protector and you can apply wax for protection in the areas where paint is visible. And don't forget to clean the under bonnet as well.
Duration: Max 4 hours.
*Just use damp microfiber towels for maintenance.
Hope this helps.
01-28-2025, 05:46 AM #17
I use American Detail Garage F bomb Diluted 1:4 in a pump sprayer. I use Carpro Iron X Pink soap or some sort of good dirt lifting soap. An assortment of brushes and then I spray it with my pressure washer. I did on mine use my air cannon on the lowest setting to dry it just because I was going to further detail it out for car showing vs spraying Koch Chemie MotorPlast on it. Always make sure and cover a distributor or and exposed air filters. Modern engines including the LS1 capable of handling water. They see plenty of it when it rains and you are driving. I just wouldn’t sit there and blast the crap out of sensors for very long on any vehicle with a pressure washer.
2002 Camaro Z28 TSP 408 With All The Supporting Mods
2019 Ford Flex Ecoturd DD Boosted With All The Supporting Mods
Washing the car in the sunshine
By Naaman in forum Showcar and DetailingReplies: 18Last Post: 03-21-2017, 01:38 AM -
Knock Sensors toast after engine washing??
By jfl330 in forum General HelpReplies: 21Last Post: 06-07-2011, 04:59 AM -
Washing or not
By coolz28 in forum Showcar and DetailingReplies: 28Last Post: 07-24-2009, 09:46 AM -
Annoying squeel after washing engine bay
By ss~zoso~ss in forum General HelpReplies: 18Last Post: 05-13-2009, 11:31 AM -
Washing/Waxing too Often?
By Shatterz in forum Showcar and DetailingReplies: 8Last Post: 05-04-2006, 08:01 AM
