Results 1 to 20 of 29
Thread: Washing or not
07-11-2009, 07:49 AM #1Junior Member
- Jun 2009
- Michigan
Red- 2002 Z28 35 Anniversary
Washing or not
I read some where that some guys never use water on their cars to keep them clean. I understand the idea of using spray detailer and micro fiber, but I am sure there are some subtle tips that make it work with out messing up the paint. Is it Common not to use water and just what technique is used??
07-11-2009, 09:12 AM #2
Also search You Tube for Optimum No Rinse
FWIW- my car is a garage queen and might go out 12 times a year max, so most of the time a light dust off of the bugs and that is, if its really dusty, I might go to the spray car wash and just rinse it off, dry down and back to the garage. But as far as a full fledged car wash with a hose and bucket, it just doesn't ever get that dirty anymore since I hardly drive it. Daily drivers I can see.Last edited by 99'CajunFirehawk157; 07-11-2009 at 11:41 AM.
Regards,
Todd
#cajunhotrodder on instagram
07-11-2009, 11:20 AM #3
07-11-2009, 11:23 AM #4
07-11-2009, 11:25 AM #5
07-11-2009, 11:42 AM #6
07-11-2009, 02:28 PM #7
mine's a daily driver. i work at a body shop in the paint dept. i wash it 1-3 times a week with water and soap. nothing wrong with it, its not goin to ruin the paint unless the water has a high mineral deposit. like well water and some other souces
07-11-2009, 02:43 PM #8
Here are a few tips on how to wash and dry your car in order to reduce swirls-
1) Implement the two bucket system- one bucket has car wash and the other is clean water. After washing a body panel always rinse the wash mitt in the clean bucket of water before dipping the mitt back into the car wash soap bucket. This prevents dirt/grit from marring the paint. You will be amazed at how dirty the clean bucket of water gets during a wash.
2) Pre soak the entire vehicle with a foam gun and rinse. This removes heavier dirt/grit before it can be scrubbed into the paint.
A foam gun can also be used while washing and prevents swirls by always having a layer of suds on the surface.
3) Use a quality car wash that has essential oils and lubricants that greatly reduce swirls. These types of car washes prevent grit from marring the paint.
4) Use a grit gaurd- it is a grate that fits in the bottom of your bucket-both wash and rinse- that helps prevent reintroducing grit back onto the surface of your car. Grit will settle under this grate. Many people rub their mitt against the grit gaurd to clean the mittt of any debris.
5) Use a quality microfiber wash mitt,sea sponge or boars hair brush when washing your vehicle. The microfiber mitt and sponge have pores so grit will not always be on the surface which reduces swirls.
6) When drying use a quality waffle weave microfiber cloth. The speacial weave keeps grit away from the surface while drying.
07-11-2009, 05:06 PM #911 years of bangin gears
- Jan 2009
- North Jersey
Mine is a DD. I use a wash mitt and I start off from the top of the car and work my way down the sides, front, and back. After I wash a panel, I hose off the wash mitt and relather for another panel. I rinse the car off twice before I lather, and twice after.
07-11-2009, 06:24 PM #10
07-11-2009, 06:41 PM #11
You can use the ONR mixed with water.
You can either spray and wipe, or use a compressed air sprayer for continuos spray. The way you do it with this pump is that you fill it up with ONR and water, and drench the car from top to bottom of the section you're cleaning. This way the mixture will encapsulate the dirt/dust and rinse it off your car. You can then wipe dry
This is the type of pump I'm talking about, or anything similar to it will work as well...
Compressed Air Pump
PS: I'm still old-fashion when it comes down to washing cars like LethalxLS1 suggested...Last edited by Z06-Goose; 07-11-2009 at 06:43 PM.
07-12-2009, 06:33 PM #12
and behind door #3.....DO NOT use a wash mitt.
There are better things to use. #1 choice is a grout sponge, found at Home Depot or similar. they have large pores. And then take a razor blade and cut it crossways (crisscrossing pattern). this allows the sponge to roll around edges/get into spots with much greater ease...and allows for even better trapping of dirt particles and keeping them off your paint....oh and cheap too!
Just some knowledge i picked up from one of the best car detailers on the planet.Last edited by bryceslu; 07-12-2009 at 06:36 PM.
07-13-2009, 01:03 AM #13
DD just hit 86,XXX and she gets a bath atleast every sat but usually she'll get 2 or 3 a week my gf thinks I have OCD or something but I just love to keep my stuff looking good! Or try to keep up with the Pewter God Y2K! But im broke and all I got is a cat back
but come get your fill on shes smooth as glass...... Im playing dont touch my shit!
07-13-2009, 06:32 AM #14King 0f n00bz
- Jan 2006
- Shepherd, Michigan
hmmm
07-13-2009, 07:48 AM #15Slow'er'Ass
- Thornton, CO
I use a sheepskin mitt and a bucket.
07-13-2009, 08:53 AM #16
07-13-2009, 09:20 AM #17
07-13-2009, 09:50 AM #18
07-13-2009, 09:59 AM #19
I only wash mine when i have to , other then that i wipe it down with this (daily)
07-16-2009, 04:45 PM #20
Washing an engine
By 024mula in forum Showcar and DetailingReplies: 16Last Post: 01-28-2025, 05:46 AM -
Washing the car in the sunshine
By Naaman in forum Showcar and DetailingReplies: 18Last Post: 03-21-2017, 01:38 AM -
Something is up with my washing machine
By kenro23 in forum Almost Anything GoesReplies: 86Last Post: 03-07-2015, 04:29 AM -
Brain Washing is fun!
By DanWS6 in forum Political / Debate ForumReplies: 45Last Post: 03-27-2008, 06:37 AM -
Dipherentdesing washing his car
By Zboner in forum Almost Anything GoesReplies: 18Last Post: 07-07-2006, 08:18 PM
