Results 1 to 20 of 27
Thread: how much for gear install?
04-06-2007, 12:26 PM #1
just trying to see what i should expect
04-06-2007, 12:32 PM #2Junior Member
- Mar 2007
- Pittsburgh, PA
Black- 1999 Mustang GT
I got my gears installed from a Local Machanic, who has worked on both my SRT-4 and Mustang.... He did my 4.10s for 180.
04-06-2007, 12:33 PM #3Junior Member
- Mar 2007
- Pittsburgh, PA
Get quality gear too, cheap gears are just gonna be trouble....
Also get a Bearing kit, and how your rear end re-built.
04-06-2007, 12:45 PM #4
i got richmonds
04-06-2007, 01:05 PM #5
Id assume around $250, as stated youll want/need an install/bearing kit
04-06-2007, 01:10 PM #6Junior Member
- Mar 2007
- Pittsburgh, PA
04-06-2007, 01:32 PM #7
04-06-2007, 02:31 PM #8in doubt tach it out!!
- Feb 2007
- Ft.pierce,fl
BADASSZ28
i do my own gear setup much cheaper just take your time and be patient itll work out
04-06-2007, 06:59 PM #9UberTapping Friction Pimp
- Mar 2007
- Omar's Tittie Taverna & Grill, Deh Rawod
18D Cock Diesel- 1999 Z28; 98 SS #2043 RIP
In Sacramento, I paid $950 for 4.30 gears and posi installed.
04-06-2007, 07:41 PM #10
400 installed with you supplying everyhting needed to install is roughly the rate that I ran into and what is what my shop charges.
Some say that the price is too high but once you figure in the tools needed to do the job, the time it takes to set them up CORRECTLY, and the education needed to get it right is well worth the price!!!
04-07-2007, 01:15 AM #11
i paid 800 for 373 richmonds, New Carrier, New positraction. installed.
04-08-2007, 02:43 PM #12
04-08-2007, 08:06 PM #13
04-09-2007, 03:00 PM #14
was it madatory for the new carriar and new posi, im asking casue i have 323's and thats next on the list
04-09-2007, 03:08 PM #15
Almost all 98-02 Fbody's came with a 3 series carrier which supported the 3.23 on to 4.10, maybe more. Most of the 93-97 fbody's that I have seen also have the 3 series carrier but I have seen 1 or 2 2 series carriers in the
93's. The 2 series carrier supports the 3.08 and lower ratio's.
Most people get a different carrier like a limited slip(Eaton, Auburn, etc) for traction issues. You don't have to get a new carrier but you'll save money in the long run doing it all at once if your wanting better performance!
04-10-2007, 01:04 PM #16
good info man, how much does that usaully run for the add ons
04-10-2007, 03:00 PM #17
I didn't exactly understand your last post but if you mean how much for install of the carrier with the gears there should be no price difference b/c you have to remove the carrier to install the gears. So if you supplied the install kit, gears, fluid, and carrier the only $$$ the shop should charge is install labor. Hope this helps!
04-10-2007, 03:02 PM #18
Free.....
youre doing it yourself you little rascal....
DIY FOREVER DIY FOREVER!!!!!
04-11-2007, 01:13 PM #19
04-11-2007, 01:14 PM #20
is that like a " detroit locker" or totally different part ( carriar, posi)
2002 Firebird Trans Am / Install 7.5-7.625-4:10 gear install
By Buick455 in forum Automatic TransmissionReplies: 3Last Post: 07-09-2015, 05:17 AM -
Help: GEAR INSTALL 3.73 vs 4.10 ????????????
By FirehawkM6 in forum DrivetrainReplies: 24Last Post: 03-04-2012, 06:30 PM -
gear install
By badblazeSS in forum DrivetrainReplies: 1Last Post: 09-18-2008, 09:16 PM -
looking for 3.73 gear/install kit
By clg82 in forum Parts Wanted / TradeReplies: 0Last Post: 06-03-2007, 04:36 PM -
Bad gear install :(
By yellowv in forum DrivetrainReplies: 13Last Post: 03-29-2007, 11:33 AM
