Results 1 to 20 of 25
    Member FirehawkM6's Avatar
    Mar 2010
    Nor Cal
    2001 Trans Am Ws6 M6
    GEAR INSTALL 3.73 vs 4.10 ????????????
    I have a 2001 Trans Am Ws6 M6.
    I have lots of bolt ons.
    Next step is installing my gears. I dont know which set up to go with 3.73 or 4.10. My car is a 6speed. Ive heard 3.73s are better for top end and speeds of 100mph+ VS 4.10s that are good for launch but lose top end and consume more gas. Which are a better setup? i hve my stock rearend and also what is a good website to order from and what else should i order to install the gears as in a install kit? any other parts that should be replaced?
    thanks for any input
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    On my 98z I had stock 342s on m6
    On my 00 SS m6 I got 3.73s difference is minimal. Can't really feel it
    I'm thinking on goin for 4.10s. If you like to take quick and al That.
    The way to go is 4.10s. 3.73s coulb better at 100+ I don't know. Nut who drives 100+ on the city? Lol
    On gas mileage I believe you drop like 2-3 miles per galon on the highway.
    I don't think you will notice that on the city
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    4.10
    East of Cleveland, Ohio
    99 WS.6 - Modified
    I can do well over 100 mph with my 4.10s. Never topped it out actually. I would go with the 4.10s. No loss of gas mileage either.
    That being said, I'd also save and get a different rear. The stock 10 bolt is weak, and at some point will break. Traction + power = a broken rear. I would upgrade to a 9". It's worth it.
    Coral Springs, Fl
    Sunset Orange Metalic
    Yup, 4.10s in a 6 speed. And like walt said, with a great ratio like that grabbing any traction dont expect wonders from your rear end, 10 bolts are notorious pieces of crap lol
    Jul 2011
    New Mexico
    2001 Trans AM WS6
    4.10 is the way to go
    Gold Member BlwnCamaro's Avatar
    Las Cruces,NM
    1998 Z28 Camaro
    I like the 4.10 ratio but 3.73 is alot stronger with the 10 bolt because its already so weak and the 4.10 pinion gear gets really small on the 10 bolt to accomodate ratio and its even weaker. I've tried both and the 3.73 lasts way longer and still has good accelleration and good midrange and top end. I have an 8.8 in my car now with 4.10's cause the 10 bolt was to weak for my combo of heads cam and juice.
    PA
    Ray Charles blue
    1492
    What? Your car will barely spin the tires.
    The 4.10s in your car felt "nice". lol "Damn it, missed 3rd gear!"
    99 WS.6 - Modified
    It only happens when I'm showing off
    I'll have to throw up some pics of the little marks I left......
    Marylandistan
    2001 Trans Am (sold)
    Quote Originally Posted by 98maro View Post
    This is false. 4:10s didn't change my gas milaege even one whole mile per gallon. Go with the 4:10s.
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    4.10's with an M6 are awesome! I have them and highway at 70mph I'm at 2k rpm
    NYC
    2000 T/A Firehawk M6
    I'm rear shopping and i'm planning on a 9inch with 4.11s
    If you google you can find a calculator that will show you the RPMs at any speed in each gear for any rear size you tell it.
    Euclid,ohio
    1998 Z28
    tranny/gear/tire size/rpm/mph calculator
    http://www.f-body.org/gears/
    Feb 2010
    Quote Originally Posted by INMY01TA View Post
    I did research on this. Every thread I found talked bout
    Dropping gas mileage city and highway
    But I never had em on my car
    So can't really say it's true.
    On city shouldn't make a difference idk bout highway
    With all of you saying this bout 4.10s
    That's gonna be my next mod! Lol
    My 3.73s are fuckin noisy!!
    PA
    Ray Charles blue
    1492
    Quote Originally Posted by LSCyaL8R View Post
    http://www.richmondgear.com/101032.html
    This one has a few ways for it. One way is in case you dont know the rear gear but you cant find out using the other variables.
    PA
    Ray Charles blue
    1492
    People say all gears are noisy but I say thats not all true. My 3.73s are pretty darn quite (pajeff02 to confirm). I went with just the stock 7.5 rear with Motive 3.73 gears, the heat treated version. Just make sure a good shop sets them up or you get someone who is good at it to help you.
    My gear swap was roughly $100 and he felt bad for charging that much! lol
    Noisy gears = installed incorrectly. If your gears are noisy, you have improper preload, improper shims, or improper backlash.
    Feb 2010
    Quote Originally Posted by TLS_Addict View Post
    mine i got them installed for $100 too lol plus $140 for gears and bearings..
    i wasnt that bad, shops on my are charge me $800 for just labor,
    the guy probably didnt set them right, they are so loud,i have the cutout open and you can still hear them lol
    but im gonna get another 10 bolt and put some 4.10s there
    Likes twisty roads bene's Avatar
    England but from TX
    Light Pewter Metallic
    2K Camaro Z28
    If you are going with higher numerical gear, make sure you use the better, 12 bolt or 9" rear. 4.10 will literally make your 10 bolt more closer to being dead. With that said, it will just be wasted money down the drain. Use that money wisely, save up for the better rear and do the gear.
    Mar 2010
    Nor Cal
    I don't have enough money for a new rear .... So I'm putting on 4.10s . If anyone has them installed on their stock rearend , how long have you had them ? Any problems?
  1. 2002 Firebird Trans Am / Install 7.5-7.625-4:10 gear install
    By Buick455 in forum Automatic Transmission
    Last Post: 07-09-2015, 05:17 AM
  2. gear install
    By badblazeSS in forum Drivetrain
    Last Post: 09-18-2008, 09:16 PM
  3. looking for 3.73 gear/install kit
    By clg82 in forum Parts Wanted / Trade
    Last Post: 06-03-2007, 04:36 PM
  4. how much for gear install?
    By 00maroz28 in forum Drivetrain
    Last Post: 04-27-2007, 01:39 PM
  5. Bad gear install :(
    By yellowv in forum Drivetrain
    Last Post: 03-29-2007, 11:33 AM
