    Junior Member sweet ss's Avatar
    Suncoast
    removing the cats from my ls1 camaro SS
    Hello everybody. I was wondering what would happpen to my LS1 if I removed the cats, and the egr system would I get considerable gains in horsepower and performance? is there a way to override the cats without taking them off?
    Junior Member silver35thss's Avatar
    auburn, al
    2002 ss camaro
    I have an 02 ss and i cut the cats off completely. I put a flowmaster in the back with 3" tubing all the way back in a Y pipe. I felt the difference immediately. The sound is great too, get compliments every day! check engine light will be on, but an oxygen sensor eliminator on the bottom 2 o2 sensors will stop the light from coming on.
    Suncoast
    cats off my LS1
    It does have a great sound.
    Where can I get those sensor eliminators?
    Did your car run rough after you cut the cats off? Mine did so I reset the PCM. It ran good for a little while then started running badly again. It started miss firing,& lost power. the same day i ran out of gas about 2blocks from my house
    I barely got home when the thing finally quit. It backfired ran rough and finally quit running right in front of my house. Since then it hasn't been running right. I thought maybe it from removing those cats.
    HAS ANYONE ELSE EXPERIENCED THAT SAME PROBLEM??
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    I haven't had a problem. I deleted the cats when I went to LT's and a ORY. I also had a friend tune out the ses light for the missing front (or was it back, I forget) O2 sensors and the deleted AIR.
    Also, what your asking about are O2 simulators (not sensors).
    BTW: I NEVER run less than 1/8 tank before I fill up as the pump will run dry and cavitate. This can be problematic.
    auburn, al
    2002 ss camaro
    When i cut my cats off the car ran fine and is still running fine, it still has that cutout, backfiring sound but mine is from the flowmaster, typical flowmaster sound. I have a buddy with another SS and he has straight headers into three inch and nothing else, loud as hell and runs fine.
    Feb 2017
    Long Beach Ca
    Quote Originally Posted by sweet ss View Post
    Have you fixed this problem ? If so how did you fix it ??
    Sweet SS has been off the site since 2009. Are you having a similar issue?
  1. removing cats on a modded already tuned car?
    By devildogws6 in forum External Engine
    Last Post: 02-17-2013, 12:00 PM
  2. Question: Need a tune after removing cats on modded car?
    By devildogws6 in forum Computer & Tuning
    Last Post: 01-23-2013, 09:39 AM
  3. Fool O2 sensors removing Cats?
    By mobb1996 in forum General Help
    Last Post: 02-06-2008, 07:40 AM
  4. Anyone experiment with removing the cats?
    By Firebirdjones in forum General Help
    Last Post: 03-10-2007, 04:48 PM
  5. removing cats
    By Semperfiws6 in forum General Help
    Last Post: 01-27-2007, 06:37 AM
