Results 1 to 20 of 21
01-21-2013, 02:03 PM #1
removing cats on a modded already tuned car?
I bought a TA with cam,ported heads, LTs, and a catted Y-pipe i want to remove cats this spring and curious if it will affect the perfomance? Or just throw a check engine light?
I tried to research.
01-21-2013, 04:18 PM #2Senior Member
- Apr 2010
- Alabama
You will most likely pick up a couple of hp by removing the cats as well as throwing a code unless the code has been tuned out. You may get a stronger exhaust smell as well.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
01-22-2013, 10:42 AM #3
Just need to tune out the rear 02's (if they haven't been already).
01-22-2013, 12:06 PM #4
I posted in your other thread about this and am in agreement with the above 2 posts.
01-22-2013, 12:44 PM #5
well i would wait to do the tune till i add or change engine seeing that a tune cost $400+ unless a local mechanic could do that?
01-22-2013, 12:47 PM #6
A mail-order tune from Frost is $150 and he could do that for you as well as other adjustments. You may have a local shop that is familiar with LS1's and have a hand-held tuner for them. This can be used as well I believe to tune out the rear 02's. The cost of that though may be around the same as what Frost charges and you will get more bang for your buck with Frost's mail-order tune.
01-22-2013, 12:57 PM #7
Hard money to swallow to just simply turn off the 02's (codes). Takes longer to fire up the laptop than it does to turn them off.
Unfortunately to get any tuner to do it that hasn't tuned the car before will cost them a couple credits ($50 last time I checked) unless they have the unlimited (aka: expensive) version. Would be best to take the car to the previous tuner since they will have the file linked to your car already on hand. Takes a whole 2 minutes to shut the rear 02's off. Buy em' lunch and call it done if they are decent people to deal with.
01-22-2013, 01:03 PM #8
The place is a 6 hr drive one way to where is was last tuned
I do have the reciept from when work was done suppose i can call and ask.
01-22-2013, 01:18 PM #9
Well, it's either that or pay Frost $150 for a mail order tune, which also requires you pull the computer and ship it to him (doesn't take long).
Or pay $4-$500 for someone local to go through and dyno/tune session, or maybe they would be kind enough to delete the rear 02's if you talk nice for a nominal fee
Or, buy the HPtuner software for about $600 and do anything you please to the car infinantly.
Either way it sounds like you're in a pickle. Aren't computer controlled cars lovely?
01-23-2013, 09:35 AM #10
Yes just so lovely Haha maybe I will hold off
02-11-2013, 11:02 AM #11
Just get a set of O2 sims , they'll run you about $100 (new).
02-11-2013, 02:55 PM #12
02-11-2013, 05:00 PM #13
OP: What kind of cats are on the car now? If you have a set of high flow aftermarket cats, you are not going to gain a whole bunch deleting them.
02-11-2013, 05:45 PM #14
To be honest i do not know because i didnt put them on, its a catback system i think maybe borla....so i am assuming its high flow, im going for louder the car is quiet in my opinion.
02-11-2013, 06:21 PM #15
How about adding a cutout? Best of both worlds.
02-12-2013, 06:07 PM #16
Yeah i was thinking of doing that, but i may change up all exhaust i just found out the muffler is rusting out! so I may live with it till next winter. Then maybe go with a true dual setup. I dont think i can put them before the cats....??? I havent taken alot of time to look under the car yet.
Thank for all the input and advice!!
02-14-2013, 03:02 AM #17I like turtles
- Aug 2007
- Corn and Soybean fields
If you're going true dual the cats are part of the y pipe so just drop it and sell it off to recoup some of the cost in your true duals. Seen some tuners run catted cars a lil richer than non catted cars so you could potentially see a slight gain in a tune. I wouldn't worry about it with the cost of a tune and just find someone to turn the codes off for now.
If your muffler is rusting apart sounds more like a Chokemaster or a Spintech to me
02-14-2013, 06:54 AM #18
Yeah I can hear it its not a good sound too me lol, damn Midwest cars.
02-16-2013, 04:22 AM #19I like turtles
- Aug 2007
Mid Atlantic and north we have the same problem
02-16-2013, 07:46 AM #20
removing the cats from my ls1 camaro SS
By sweet ss in forum Camaro / SSReplies: 6Last Post: 02-08-2017, 04:04 PM -
Question: Need a tune after removing cats on modded car?
By devildogws6 in forum Computer & TuningReplies: 5Last Post: 01-23-2013, 09:39 AM -
00 Z28, A4, modded, tuned, NJ
By ShadowHawk in forum Vehicles For Sale / TradeReplies: 12Last Post: 09-19-2010, 02:33 PM -
Cats for a Non-cat exhaust....Re-tuned CPU
By sbackof in forum External EngineReplies: 4Last Post: 12-26-2009, 01:46 PM -
removing cats
By Semperfiws6 in forum General HelpReplies: 19Last Post: 01-27-2007, 06:37 AM
