Results 1 to 20 of 20
Thread: removing cats
01-25-2007, 03:14 PM #1boycott wal-mart
- Jan 2007
- S. Carolina
silver- 98 T/A WS6
removing cats
my check engine light just came on. the codes say its either an o2 sensor, or the catalytic converter (bank 2) if i remove the converters, and therefore the o2 sensor, will the check engine light stay/go on? anybody know? 98 t/a ws6.
01-25-2007, 03:21 PM #2
Yes the light will stay on unless you install o2 sims
01-25-2007, 03:32 PM #3boycott wal-mart
- Jan 2007
- S. Carolina
silver- 98 T/A WS6
whats an o2 sim?
01-25-2007, 03:40 PM #4
it replaces your o2 and it reverses the code to make it look like you have cats
01-25-2007, 03:41 PM #5
there called o2 simulaters they plug into the rear o2 sensors when removing
the cats. they tell your cars computer that the cats are there and working fine.
01-25-2007, 03:44 PM #6
Now remove your EGR and AIR and you'll have to tune em out to kill that SES light.
01-25-2007, 03:46 PM #7
what does removing your egr do? are there any pros or cons?
01-25-2007, 03:52 PM #8
wait a minute all you are trying to do is get rid of your check engine light
right ?
01-25-2007, 03:53 PM #9boycott wal-mart
- Jan 2007
- S. Carolina
silver- 98 T/A WS6
yes.
01-25-2007, 03:56 PM #10boycott wal-mart
- Jan 2007
- S. Carolina
silver- 98 T/A WS6
yes, but i want the problem fixed and i dont know how to tell if its the o2 sensor or the cat. i figured i would start with the o2 sensor. the code is not specific.
01-25-2007, 04:01 PM #11
if your cats were bad or you rear o2 sensor are bad all you have to do is
install o2 sims.
01-25-2007, 04:03 PM #12
unless its your front o2 sims that are bad
01-25-2007, 04:06 PM #13boycott wal-mart
- Jan 2007
- S. Carolina
silver- 98 T/A WS6
but if its my cat, wont that eventually effect driveability?
01-25-2007, 04:11 PM #14
if its your cats the check engine light wont go away
01-25-2007, 04:12 PM #15
i had a firebird v6 with a blown internal cat and it took me 10 minutes to hit 60mph so i think in some cases it would
01-25-2007, 04:13 PM #16
if the light goes away after you fix the o2's then you know the cats are fine
01-25-2007, 04:14 PM #17
your front o2's should be fine if your cat went bad it might make the year o2's go bad so i would replace cats and rear o2's
01-26-2007, 02:52 AM #18Junior Member
- Sep 2006
- Hunstville, AL
GM Bright Red- 2002 Trans AM WS-6
I have true duals with no cats and my car runs perfect.... how would not having cats effect the car that much?? and my check engine light isn't always on.. it comes and goes as it pleases.. took it to the dealer and they always tell me "if you would return the exhaust to factory settings the light wouldn't come on.." haha but that wouldn't be as cool!!!
01-27-2007, 06:35 AM #19Stang Reaper
- Nov 2006
- Missouri
Pewter Metallic (1of?)- 2001 Formula M6(1 of 225)
Cats are just an emissions control device, they are not necessary in the operation of an internal combustion engine people. It is on bank two and the only way the computer senses a problem is through sensors, it doesn't know the actual condition of the cat until the exhaust gases hit the downstream o2 sensor (the one right behind the cat). If you take the car to somebody who can tune your car or pay about 80 bucks for some o2 sims, the light will go off, I had my cats taken out and had a guy tune the rear o2 sims to read a fixed reading.
01-27-2007, 06:37 AM #20Stang Reaper
- Nov 2006
- Missouri
Just remember that a check engine light doesn't mean the car is going to self destruct. Just run the codes, and it generally comes out to be a faulty sensor or something to that extent.
removing the cats from my ls1 camaro SS
By sweet ss in forum Camaro / SSReplies: 6Last Post: 02-08-2017, 04:04 PM -
removing cats on a modded already tuned car?
By devildogws6 in forum External EngineReplies: 20Last Post: 02-17-2013, 12:00 PM -
Question: Need a tune after removing cats on modded car?
By devildogws6 in forum Computer & TuningReplies: 5Last Post: 01-23-2013, 09:39 AM -
2000 SS, M6, question about removing cats
By steiger99 in forum External EngineReplies: 3Last Post: 03-20-2009, 11:32 PM -
Anyone experiment with removing the cats?
By Firebirdjones in forum General HelpReplies: 5Last Post: 03-10-2007, 04:48 PM
