    pimp spookyz28's Avatar
    Long Beach Ca
    What do you think about 42lb fuel injectors?
    I have a 2000 Z28 camaro Mods are long tube headers, stage 3 port and pollished heads, Manley Nextec Beehive springs and valves, Weiand aluminium intake port matched to the heads, 1.8 Krauer Roller rockers, custom grinde LS7 Hot Cam with a lift of .625, 57 series FIPK breather filter, and the SLP cold ram air box. My question is, when I get the dyno tune can I go with 42 LB injectors? I did not touch the bottom end of the motor. When I get the tune will I be able to adjust the flow rate of the injectors to a constant fuel flow? or will I have to go with smaller ones? With these mod's we are expecting 500 to 550 at the flywheel.
    Aug 2006
    Missouri
    94 Camaro Z28
    Technically, you can go with bigger injectors, but unless you're running FI, I don't think you'll need them. And really, the dyno tune will really be able to tell you if you need more fuel and if your injectors are maxed out. I'm thinkin since you're running all motor, the stock injectors should suffice.
    Member M6HUGGERSS's Avatar
    san diego
    millenium yellow
    2002 corvette Z06
    depends on duty cycle of your injectors....
    get the car dynoed, your tuner can tel you for sure...
    sounds like you should be fine!
    315rwhp 98 SILVER Z28 (3500lbs)- SOLD
    400rwhp 99 HUGGER SS (3375lbs)- SOLD
    340rwhp 02 YELLOW Z06 (3040lbs)
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    I would say yes. I have a cam only car with a MS4 cam and I'm seeing duty cycles well above 80%. I'm making about 410rwhp or so. I need to re-dyno the car again after I finish the tune. But it sounds like you are making more power than I am so I would highly recommend them. You will need to have the car re-tuned for the bigger injectors (it is not a complete tune just changing the pertinent values in the pcm to match the extra flow of the new injectors). But since you haven't tuned it yet it can all be done in the same shot. My .02
    2000 NBM Camaro Z28
    Mods:
    SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
    Aug 2006
    Missouri
    94 Camaro Z28
    But the MS4 cam is a HUGE cam.
    Don't know the specs of the LS7 hotcam.
    Member danziger's Avatar
    Aug 2006
    Chesapeake, VA
    Le Mans Blue
    2004 Z16
    If you really have to upgrade (which I don't think you do yet), I would go with the SVO 30lb injectors. They will flow plenty at the LS1's rail pressure, cost less and will be easier to tune.
    North Olmsted, OH
    Quote Originally Posted by BlackLT1Z28 View Post
    It is not a matter of size of the cam but horse power. You can use the calculator at the bottom of this page. In order to keep you injector duty cycles within less than 80% you'll need bigger injectors for your current target hp (500 fwhp). 30# SVO should work as well but for the price you might as well get 42# SVO's and have extra room to grow. Of course this is my opinion and you can just wait until you are dyno tunning and see what the tuner says. But that will mean that if you are running out of injectors you will have to order a set, wait for them to come, install them, re-tune and re-dyno, and 1-2 weeks later you get to finally have fun with the car. Ask your tuner what he thinks if he has done other LS1/6 he will have a good idea of what you'll need for your target power level.
    P.S. the only reason the SVO 30# will work is because they are rated at 30# @ 43.5psi an LS1 will run around 58-60psi so in reality they will flow more like a 35# injector.
  1. fast electronics 42lb fuel ijectors
    By SILVER BULLETT in forum External Engine
    Last Post: 05-11-2012, 01:34 AM
  2. green top 42lb injectors brand new 199.00 shipped!
    By 1fastcamarosss11 in forum Parts For Sale / Trade
    Last Post: 11-18-2009, 09:06 AM
  3. For Sale: 42lb injectors,suspension parts
    By Qwk94Z28 in forum Parts For Sale / Trade
    Last Post: 04-07-2008, 04:03 PM
  4. smaller fuel injectors means more fuel?
    By Ger-Fire in forum LT1
    Last Post: 10-12-2006, 03:06 PM
  5. WTB or TRADE: 42lb injectors and/or Boost pump
    By mavrikZ in forum Parts Wanted / Trade
    Last Post: 08-02-2006, 07:41 AM
