Results 1 to 3 of 3
    Junior Member SILVER BULLETT's Avatar
    Tipton,Mi
    00' WS6 Trans Am
    fast electronics 42lb fuel ijectors
    I have tried to order 2 seperate sets of the fast electronics 42lb fuel injectors only to have my orders canceled after being told they not available.I have already sent my ecm out to frost to have tuned for the 42lb injectors, located a couple of other sets but they are over $800 for set,part # is 304208. My mods are are #243 heads cnc ported w/stock valves, comp cams 54-460-11 grind (235/243 .621/.624) 113 LSA kit w/matching components,ls7 lifters,ls6 intake, ported t/b, longtubes,off road, m6, 4.10's, stock bottom end w/ 18000 original miles,just installed all the mods,any suggestions for replacement/alternative injectors greatly appreciated.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Try Siemens
    Member cowstandmoto's Avatar
    Houston, Texas
    Dark Blue Metallic
    2002 Trans Am WS6 M6
    You should also check ws6store.com They have the 42# at several different prices. I use them for almost everything.
  1. FAST 102 aftermarket Ls1 fuel rail?
    By seweber in forum External Engine
    Last Post: 02-18-2015, 09:56 PM
  2. Help: FAST fuel rails
    By sutie in forum External Engine
    Last Post: 11-17-2010, 10:02 AM
  3. What do you think about 42lb fuel injectors?
    By spookyz28 in forum External Engine
    Last Post: 04-01-2007, 08:22 PM
  4. Tanner Foust Life In The Fast Lane - Car Audio and Electronics Magazine
    By Ed Blown Vert in forum Stereo and Electronics
    Last Post: 09-15-2006, 07:28 AM
  5. Fuel pump wont come out...need help[ fast!!!
    By ttocs in forum General Help
    Last Post: 04-28-2006, 05:53 PM
