    Mexico
    Trans Am 97
    smaller fuel injectors means more fuel?
    I have tuned my Lt1, the programmer guy told me that my system was running a little lean, so, he let it know to the pcm that i was running a smaller fuel injertor size, this way, the pcm will inject a little more gas.
    is that true?
    I have full SLP exhaust system, CAI, 160 degree stat,iridium spark plug,wires.
    thanks in advance-
    Aug 2006
    brew city
    96 impala
    in short,yes.
    if you tell the pcm the injector is smaller than it really is,it will send a longer pulswidth.
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    thats cool to know
    Iowa
    1993 Vette
    yes tricking the pcm into raising the pulse width will work but fuel injectors are not rated for a %100 duty cycle I belive its more like %30 in a nut shell yes a fuel injector can supply more fuel than rated for with higher fuel press and a longer pulse width butthis will reduce the life of your injectors by how much depends on how far you push it
    Buffalo
    your car will also get more air than what the PCM thinks, if you port the MAF.
    Aug 2006
    Missouri
    94 Camaro Z28
    I don't know if I would ever mess with the MAF, those things are good to support close to 500hp anyways. And if you screw up, you'll have to get another one anyways.
  1. Question: fuel injectors
    By Blackbird WS6 in forum General Help
    Last Post: 09-19-2010, 11:53 AM
  2. lt1 fuel injectors
    By 6801 in forum LT1
    Last Post: 02-15-2010, 07:56 AM
  3. LS1 all yr fuel injectors, oe fuel rail, pump,more
    By Frost in forum Parts For Sale / Trade
    Last Post: 04-27-2009, 02:26 PM
  4. 32# fuel Injectors
    By 95TA383 in forum Parts For Sale / Trade
    Last Post: 04-26-2007, 02:42 PM
