Results 1 to 13 of 13
Thread: no turn signals! need help!
03-20-2007, 04:46 PM #1
okay Im new to corvettes just bought my first an 01. so I just put it on the road and the blinkers stop working as well as 4 ways. checked fuses all are good played with hazard switch and actually managed to play with it enough to get the 4 ways to work. now the signals work when they want to but speratically. so far ive diagnosed it to the flasher/blinker and four way switch because they are one in the same. also because its only a 30$ part and causes me to tear into my dash. so hopefully one of you wonderfull jents has had the same problem and could give some advice or atleast point me in the right direction.
03-20-2007, 05:08 PM #2
- Mar 2007
- Quantico Virginia
Black on Black- 2000 Camaro SS M6
I just changed my corner lights and had a similar problem. i pulled all my bulbs and found one of the turn signal lights was in backwards. your problem sounds slightly different than mine though. good luck!
03-20-2007, 05:40 PM #3
oh and the only thing i have done prior to all of this was installed a sets of black covers on the rear lights which screw on with the stock lens covers using the stock screws but I dont know or think that could or should cause a problem i hope
03-21-2007, 03:27 AM #4
- Mar 2007
- Quantico Virginia
maybe one of the bulbs are loose in the back from the vibrations. if the problem started after that install, i would check that. (im no expert though)
03-21-2007, 03:30 AM #5
- Jan 2007
- Lake Geneva, Wisconsin
millenium yellow- 2000 corvette
It sounds like the hazard switch.I have the same problem on my '00 coupe. I take my knuckle and hit the hazard switch and that usually works. So I eventually will replace the switch.I have heard alot of other complaints on the same issue,so it is a common problem.Heres a write up on replacing the switch.http://myweb.cableone.net/kd5fx/HSwitch/HSwitch.htm
03-25-2007, 08:39 PM #6
- Mar 2007
- washington
torch red- 2001 c5
anyone else having (service active handling) lights and warning intermitently?
usually after driving 10 miles or so. (2001 c5
03-25-2007, 10:03 PM #7
I'm not sure how the Corvettes work compared to Camaros, but my blinker stopped working and I couldn't figure out why, turns out my front bulb burnt out and it stopped my blinker from blinking. just had to change a bulb and it worked again. might be able to help you, might not.
03-25-2007, 10:24 PM #8
Move to Colorado. Nobody here uses turn light signal, it seems
2007 Audi RS 4
03-26-2007, 05:23 AM #9
03-26-2007, 05:35 AM #10
- Mar 2007
- washington
torch red- 2001 c5
Thanks, i will try that
03-31-2007, 05:30 AM #11
Could also be your turn signal module. It was located under the dash in my 98 Camaro. Black box with approximately 10 wires coming out of it. Controls turn signals and flashers.
03-31-2007, 08:08 AM #12
- Mar 2007
- washington
torch red- 2001 c5
Thanks Larry,but i followed Lethal Tendecies directions and voila no more problem. So thanks to all
04-16-2007, 08:44 AM #13
no more problems changed the flasher unit! thanks!
turn signals
By pewterz55 in forum Stereo and ElectronicsReplies: 15Last Post: 06-24-2010, 05:17 PM -
turn signals
By pewterz55 in forum Camaro / SSReplies: 1Last Post: 08-11-2009, 06:12 PM -
Turn signals!!
By youngun67 in forum General HelpReplies: 5Last Post: 02-17-2009, 09:09 AM -
Turn Signals
By bb4ninja in forum General HelpReplies: 14Last Post: 04-16-2008, 04:17 PM -
Help: turn signals
By joker in forum Stereo and ElectronicsReplies: 2Last Post: 04-12-2008, 12:18 PM
