Results 1 to 15 of 15
Thread: Turn Signals
    Junior Member bb4ninja's Avatar
    Pewter Metallic
    2000 Pontiac Trans Am
    Turn Signals
    Im having issues with my driver side turn signals, it wont flash, the arrow on the cluster just stays lit and ive already replaced the front and rear bulbs, and the fuse for the turn signals. Could it be the flasher? or some kind of short
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    yeah flasher is what id change next
    Bragg NC
    Met. Sunset Orange
    01 SS
    Check the actual housing and ensure its free of rust and corrison.
    J
    Muncie, IN
    Quote Originally Posted by sunsetorangess View Post
    J
    definately a possibility. . . does your driving lights/turn signals come on? one time my driving lights would come one but wouldnt flash. i thought just one filament was burnt out but it wasnt. corrosion in the socket just needed cleaned out
    have you checked your turn signal sluid level...
    Colorado
    RIP S4 06Tbss
    Im 99.9% positive it is your flasher. Mine did the exact same thing that you just discribed. Changed mine and they work fine now. Any local auto store has one for cheep, and the flasher is under your steering wheel under that panel right where your knees sit off to the upper right hand side, pretty ez fix.
    Member youngun67's Avatar
    WI/NC
    red/black
    98 T/A
    i have a quick addition to that i had the same thing happen to mine on the passenger side and the driver side worked fine than about 2 weeks later the driver side did the same thing would you think flasher as well?
    Quote Originally Posted by bb4ninja View Post
    teh little hole under your runnnig light is the access to your light... pull the bulb take it in to walmart with you and get a new one... you have to twist it untill it clocks or stops then pull the bulb out... rever to put the new one in...
    yes.. you have a dea signal bulb...
    Pewter Metallic
    Thanks for the help guys, tommorow ill head down to the local autozone and get a new flasher, if that doesnt work ill check the sockets, they seemed ok to me but doesnt hurt to check again
    homer glen il
    1998 bmw z3
    I believe if it was a flasher it would effect both sides... I've seen problems with gm bulb sockets having bad ground connections in the socket. with the turn signal on you may also want to wiggle the wires on the bulb socket see if it starts to flash
    Pewter Metallic
    Just wanted to thank everyone again, i replaced the flasher and all is well again
    Muncie, IN
    awesome man!!!! glad its fixed!
    Jan 2008
    2000 Trans-Am
    Figured I'd use the same thread, instead of starting a new one named 'Turn Signals'.
    Mine don't work at all on either side. It won't even light up (like what happens when a bulb goes out, lights up but wont flash).
    I replaced the flasher, checked the fuse, and all the lights light up fine. When I turn on the turn signal, both flashers (the old and the new replacment) make a very faint buzzing noise.
    Anyone have a clue?
    Muncie, IN
    Quote Originally Posted by vx15i View Post
    Anyone have a clue?
    hmmm. . . maybe a bad ground somewhere
    Jan 2008
    2000 Trans-Am
    Well, after many hours of troubleshooting, I narrowed the problem down to the 'DRL box'. Disconnecting the DRL harness from the box fixes the problem, but of course the DRLs no longer work.
    There is not a whole lot inside the box that looks like it could go bad. A controller chip and two inductors.
  1. turn signals
    By pewterz55 in forum Stereo and Electronics
    Last Post: 06-24-2010, 05:17 PM
  2. turn signals
    By pewterz55 in forum Camaro / SS
    Last Post: 08-11-2009, 06:12 PM
  3. Turn signals!!
    By youngun67 in forum General Help
    Last Post: 02-17-2009, 09:09 AM
  4. Help: turn signals
    By joker in forum Stereo and Electronics
    Last Post: 04-12-2008, 12:18 PM
  5. Turn Signals!!
    By 2001bird in forum Stereo and Electronics
    Last Post: 01-07-2008, 09:40 AM
