Results 1 to 16 of 16
Thread: turn signals
06-19-2010, 11:35 AM #1
turn signals
hey all. when i got in my car today my signals did not work. they were working fine yesterday. when i click em on nothing shows up on the dash or anything. ive changed all the bulbs and the flasher within a couple months so im assuming it might be the fuse. which fuse would it be? or are there any other possiblities of why this happened?
06-20-2010, 08:40 AM #2
06-20-2010, 08:44 AM #3Member
- Northern Virginia
BLACK- 2000 Camaro SS
Yep, check the fuse. It's behind the little panel on the left side of the dash. The fuse is labeled "TURN-B/U" or something like that. You can also put your car in reverse with the key on to see if your back-up lights are working. If the fuse is blown, the back-up lights won't be working either.
06-20-2010, 02:46 PM #4
back up lights and hazards are working. i pulled the fuse and checked it, it was good but i switched it anyway. still same problems doesnt show up on dash and none of the lights flash????????
06-20-2010, 04:17 PM #5Member
- Northern Virginia
That's a bit of a stumper. Sounds like maybe something in the switch mechanism that is normally activated by the turn signal lever.
06-20-2010, 04:34 PM #6
If you're tall you may have jammed the lever with your knee and it broke the signal switch inside.?.
06-21-2010, 01:49 AM #7
I'm not tall but I thought it might be the lever. It feels the same though not like limp or anything.
06-22-2010, 01:12 PM #8
changed all the bulbs today... nothing. should i take it to a dealer?? any one ever had this problem that may know wat to do?
06-22-2010, 09:48 PM #9
Do you hear the flasher clicking under the dash? If not you may want to go pickup a electronic flasher at any auto parts store. I hate mechanical ones and I have LEDs so i have to use electronics.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
06-24-2010, 11:45 AM #10
well im gonna try and figure this out today. do i have to take the steering wheel off to get to this or wat? whats the easiest way to go about it.
06-24-2010, 12:30 PM #11
no need to remove the steering wheel, just the kick panel under the column. The flasher on my t/a is located on the right side, clipped to the metal rail...but you can only see the clip, its on the right side of the rail (ie: directly behind the HVAC controls if that makes sense). I assume it should the be same location for a camaro.
06-24-2010, 02:00 PM #12Senior Member
- Feb 2006
- Orange County, NY
Do the hazards work?
06-24-2010, 02:43 PM #13
turned out it was the flasher...... i didnt think it was cuz i just changed it about 6 months ago and when it went out the light stil lit just didnt flash. thanks for all the help fellas i appreciate it. now to the next problem lol ses light
06-24-2010, 03:46 PM #14
Do you know what codes are coming up? If not, you can just go to autozone and have them read it for you.
06-24-2010, 04:02 PM #15
06-24-2010, 05:17 PM #16
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
Sounds like you need to replace your passenger side cat. Or if you got a bad tune...it could just be the tune. I had a horrible tune and kept popping up P0420 and P0430 codes right after installing new O2 sensors and new cats. I finally went somewhere else that does alot of LS1 work and haven't had issues since.
turn signals
By pewterz55 in forum Camaro / SSReplies: 1Last Post: 08-11-2009, 06:12 PM -
Turn signals!!
By youngun67 in forum General HelpReplies: 5Last Post: 02-17-2009, 09:09 AM -
Turn Signals
By bb4ninja in forum General HelpReplies: 14Last Post: 04-16-2008, 04:17 PM -
Help: turn signals
By joker in forum Stereo and ElectronicsReplies: 2Last Post: 04-12-2008, 12:18 PM -
Turn Signals!!
By 2001bird in forum Stereo and ElectronicsReplies: 4Last Post: 01-07-2008, 09:40 AM
