    Member Whiteboycntdnce's Avatar
    Virginia
    2000 / SS
    Turn signal issue
    2000 SS ... The rear right turn signal doesnt work. The light on the dash stays solid when turned on. The right front works, but doesnt blink... The left hand signals all work, when you put the 4 way flashers on, they all flash minus the right rear signal... Ive pulled the bulb and tested it, it's good... I put a test light on the socket and it's getting power but only one solid current, no flash... Any ideas?
    Quote Originally Posted by Whiteboycntdnce View Post
    This happens when the bulb is burned out.
    Painted manta stripe
    Virginia
    2000 / SS
    I know normaly thats the case, but the bulb is fine, I even took it out of that socket and put it in the left rear socket and it worked fine
    Member luvmyz28's Avatar
    Feb 2007
    Council Bluffs IA
    nbm
    99 z28
    try bending the metal tabs out on the bulb. I had the same problem, the bulb just was'nt making contact with the socket.
    SMKDFRD
    Guest
    Just go to kragen, autozone or where ever and just buy a new bulb. They're only like $5-$10 bucks. If problem is not resolved just return bulb. Then you'll know for sure it's not the bulb. Ha, ha.
    SMKDFRD
    Guest
    Ah Y2KPewterss, This is a little off topic but where did you get your burger panel? Or did you just paint the original?
    Member bevenue's Avatar
    Aug 2006
    Tulsa, Oklahoma
    2001 camaro SS A4
    Heres your problem. Try this http://kalecoauto.com/index.php?main...&products_id=6 LOL
    Bad bulb, Needs a better connetion, or Chase the wires
    [SIGPIC][/SIGPIC]
    SS #2988, A4, Navy Blue Metalic, 335HP Dual Dual Exhaust, Chrome 10 spokes, Floor mats, Dash plaque, and SS Grille
    Best ET 13.08 @ 106.1, 2.00 60', with SLP lid
  1. Turn Signal
    By wkstyle in forum Firebird / WS6
    Last Post: 09-30-2015, 06:19 AM
  2. Turn Signal
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 11-15-2010, 05:58 PM
  3. Turn signal/hazard issue (left side out).
    By tyler durden in forum General Help
    Last Post: 09-20-2009, 12:29 PM
  4. turn signal/drl bulb issue
    By 1MileCrash in forum General Help
    Last Post: 11-06-2008, 05:44 PM
  5. headlight and right turn signal issue
    By nate_the_great17 in forum Firebird / WS6
    Last Post: 09-06-2007, 11:03 PM
