    Junior Member tyler durden's Avatar
    Aug 2009
    VA
    Turn signal/hazard issue (left side out).
    This is for a '99 Camaro...
    When attempting to operate the left turn signal...the left turn indicator in the dash stays lit and neither bulb functions. The bulb for the left rear indicator/hazard works for the hazards, but not the turn indicator. The front left bulb is out...period. I've already replaced both of the bulbs. The turn signal and hazard function for the right side of the vehicle is fine.
    According to the Haynes manual...the turn signal switch functioning for the right side indicator, but not the left indicates a bad bulb. As I've replaced both of the bulbs in question...I'm at a loss at the moment.
    I've spent a couple hours going through the dozens of threads with nearly identical issues, but mine seems to be just a bit different. I appreciate any input you can offer.
    Stockitie Stock Stock 95camaroZNC's Avatar
    Raleigh NC
    1999 Trans Am
    Mines doing the exact same thing...... subscribed.
    Member RealLiveMD's Avatar
    Feb 2006
    Memphis
    2002 WS6
    check for corrosion. there is a bad connection somewhere. perhaps you didn't seat the bulb all the way in the socket. If its a trans am I'm will to bet that you need to replace the socket whick you can do for five dollars from oreilly or autozone.
    Feb 2007
    canada
    pewter
    2001 WS6 T/A
    Had the same problem with my 01 t/a, it was corrosion in the light socket
    up front. purchased two new pig tail sockets and repaired. works great now
  1. How to replace your turn signal and hazard flashers
    By JayTA98 in forum General Help
    Last Post: 05-26-2011, 06:18 PM
  2. turn signal/drl bulb issue
    By 1MileCrash in forum General Help
    Last Post: 11-06-2008, 05:44 PM
  3. Left Turn Signal Problem
    By 6speedTAthistime in forum Firebird / WS6
    Last Post: 11-21-2007, 06:53 PM
  4. headlight and right turn signal issue
    By nate_the_great17 in forum Firebird / WS6
    Last Post: 09-06-2007, 11:03 PM
  5. Turn signal issue
    By Whiteboycntdnce in forum Camaro / SS
    Last Post: 03-20-2007, 06:45 PM
