View Poll Results: Does your f-body have gear whine?
Voters
166. You may not vote on this poll
  • YES
    127 76.51%
  • NO
    39 23.49%
Page 1 of 8 12345 ... LastLast
Results 1 to 20 of 146
    NW Chitown
    2002 WS6
    Rear end whine, who's got it?
    I just picked up a 2002 WS6 with the 6spd.... I'm noticing that the rear end has (what I would consider) a loud whine at about 50-70mph. Its loudest @ 60ish, but once you clear 70 its gone again. Bad news for me is that most of the speed limits around my house are 55mph... so the SOB whines really bad on pretty much every street I drive.
    I did search a bit and I noticed that pinion seals commonly leak, but the whine I can't find much on. My pinion seal appears to be in fine condition.
    Is gear whine common in these cars? Whats the best cure for this cuz its going to drive me crazy. Whats the best lubes to use?
    If the gears have to be replaced to fix this... I'm taking it back to the dealer TOMORROW and those clowns are going to fix it.
    Thanks for any suggestions.
    BTW, the damn car is FAST.
    -Eagle
    | '02 WS6 M6 | KOOKS/ORY | LC-1 | LOU'S SS | UMI SFCs | BMN LCAs & RELOC's | Hotchkis STB | HSW 150 shot | Lid | 42# Lucas | HPTuner Pro |
    386HP 373TQ jwindbigler's Avatar
    San Diego...Michigan originally
    1999 Trans Am 5.7L
    Very low pitch. Its pretty common on these cars. The rear ends also have a tendancy to leak a little bit too.
    Florida
    2002 Trans Am WS6
    I have it. Had it since the day I drove it off the lot. Mine happens between 50 and 60. Once I clear 60 its gone.
    Member BrntWS6's Avatar
    Land of the FOID
    SOM
    2002 WS6 M6 - 461hp 406tq
    I have mine at the same speed, 60mph then it's gone 2mph either direction. I brouht it into the dealer back in '01 when I bought the car and they couldn't fix it. They actually just made it worse because after that the pinion seal has leaked, which it never did before that. I took it in 3 times at two different dealersips for new seals and it's always good for a little while, then it starts leaking again. Now my warranty is up, but it's pretty sad when those idiots can't even repair a simple seal correctly.
    Philly area
    it could be the gears growling a bit when it changes from 2nd to 3rd?
    Florida
    2002 Trans Am WS6
    It's got nothing to do with going from 2nd to 3rd. You can be just cruising and it happens. It's a constant whine between 50 and 60 and even with just a tad bit of gas in between those speeds makes it even louder. Once past 60 though, it's gone.
    Philly area
    I don't man, have it checked, or if you plan on doing some serious mods, get a 12 bolt anyways to support that tq
    Rhode Island
    Arctic White Hardtop
    '98 Formula M6
    Quote Originally Posted by NvyBluMtlc02WS6 View Post
    same thing happens to me. I've just learned to deal with it. I pay more attention to the sound of the engine and watching my revs anyway.
    NW Chitown
    2002 WS6
    Yeah, mine happens during cruising as well. Romp on it and the exhaust noise easily covers the whine! Bad news is, I cruise at 55mph pretty much 80% of the time during my commute to and from the office...
    Philly area
    pump up the music. that should cover loud ass exhaust too
    NW Chitown
    2002 WS6
    Thats a good point too... how often do the stock axles fail? About how much power / abuse can they hold? Last thing I need is the car spitting out an axle on me...
    Rhode Island
    '98 Formula M6
    Quote Originally Posted by Eagle View Post
    yeah, the road I take several times a day thats right outside my house has a speed limit of 45 so im always going about 50ish, and its like this for a good 3 or 4 miles. and theres TONS of cops on this road so I hardly ever take it over 55.
    NW Chitown
    2002 WS6
    The whine just has to go tho... its gonna drive me nuts. Anyone out there heard of ppl changin out the R&P to fix the howl?
    Member gd1996's Avatar
    Latrobe, PA
    I had some that did, some that didnt... I had one that pinion bolt was loose and only whined on decel, but a little tightening fixed that. A properly setup rear should not whine, especially something factory!
    NW Chitown
    2002 WS6
    Quote Originally Posted by gd1996 View Post
    Thats what I'm saying... yet looking at the poll it seems to be pretty common. I've had quite a few 10 bolt axles in my day... not sure why this 2002 should howl when all the others hadn't.
    Aug 2006
    West, Central, Florida
    2000 Pontiac Formula
    It's most likely a messed up wear pattern on the ring/pinion. Once that happens, you'll never get rid of it. If it's whining at a certain RPM range, it's telling me it's the wear pattern. Sorry man but you'd have to change the gears for that to go away.
    I tried to set the record for jacked up 10 bolts. I've broken 6 of 'em. lol! I know every gear noise known to man. haha.
    Rollo Tomassee AKIRA's Avatar
    Outside the box
    From stock to Richmond gears, Ive never heard a whine. BUT. When my rear sounded to 'howl,' I looked into it. A pinion bearing blew and I needed replacing. Fucked up my axle a little bit, so I put "axle savers" on.
    Member luvmyz28's Avatar
    Feb 2007
    Council Bluffs IA
    nbm
    99 z28
    mine was doing that and it ended up being the pinion bearing.
    Member Tony180a's Avatar
    Clarksville, Tn
    1999 Trans Am WS6
    I didn't have a whine but a roar, it was axle bearings but luckily the race was ok. I plan to get a 12 bolt his year.
    Junior Member 00TAWS6's Avatar
    Alabama
    2000 Trans Am
    Not trying to scare you or anything, but my car was doing the same thing. Took it to the dealer(still under warranty) My pinion seal had spun around in the rear end causing that noise. They ended up having to replace the WHOLE rear end. I didn't care though the $2500 I paid for the extended warranty took care of that. It was like a $3200 job if I recall correctly.
    Jimmy
  1. Whine from the rear
    By Craigk in forum Drivetrain
    Last Post: 06-05-2012, 04:07 PM
  2. Question: rear end whine..
    By gav91183 in forum Drivetrain
    Last Post: 08-31-2010, 05:33 PM
  3. Rear End Whine '01 Z28
    By David Ray in forum General Help
    Last Post: 07-31-2009, 03:49 PM
  4. Rear End Whine
    By Blackout01 in forum Drivetrain
    Last Post: 07-21-2007, 08:35 AM
  5. Rear end whine??
    By speedydog in forum General Help
    Last Post: 04-12-2007, 04:45 PM
