    Nov 2011
    St. Louis, MO
    2000 Trans am conv ws6
    Whine from the rear
    As I drive my car if my foot is on the gas there is not a problem but when I remove my foot and coast there is a whine that comes from the rear. Any ideas?
    Indianapolis
    2000 WS6 6spd Hooker LT
    Yes. Sounds like a differential bearing is bad. Hard to diagnose over the internet, of course. Does it change when you go around a corner, loaded or unloaded?
    Member Supershafts's Avatar
    Apr 2010
    Long Island, N.Y.
    1971, 73,78, 85,92,95,
    Better look at it now before it sucks the pin in... that is the start of a loose pin, which means either you have a pin nut loosening or bad pin bearings.
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    If it's a whining sound, I would think it is a problem with the ring and pinion. If it were a bearing, I believe the sound would be more of a growling/rumbling/chattering sound. With foot off the gas, I would think it has to do with the backlash of the ring and pinion. It's not hitting the coast side (the back side) of the gear teeth properly. Pinion depth may be the problem, or back lash may be incorrect or out of spec/adjustment. The only way I know of to fix this, though would involve removing the whole diff. Not sure if on these cars the backlash/pinion depth is on-car adjustable.
    Have you checked the fluid?
    Also, does this happen when driving straight or when turning one direction? Both directions?
    Apr 2010
    Long Island, N.Y.
    As a bearing goes bad or loosens up what happens ? settings change and when dealing with settings that have a .001 importance of being on or off, a loose or failing bearing or nut backing off will do exactly as stated.
    Since the op like everyone else doesn't use much detail and we have to guess that the car suddenly started doing this and it wasn't recently rebuilt by a non professional then it would be the pin area that is of concern.
    Nov 2011
    St. Louis, MO
    Have not done anything. Kind of laid up, I have to get back surgery. I will check the fluid and then do the checks with turning. Car has been doing this for a while, 2000 miles maybe.
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Quote Originally Posted by Supershafts View Post
    Touche, monseur.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Sounds like the carrier bearings are on the way out. Not an expensive fix. Should run you less then 100 dollars and about 4 hours of time. If you have R&P wear I would start looking into a 12 bolt or a 9". Good luck.
  1. Question: rear end whine..
    By gav91183 in forum Drivetrain
    Last Post: 08-31-2010, 05:33 PM
  2. Rear End Whine '01 Z28
    By David Ray in forum General Help
    Last Post: 07-31-2009, 03:49 PM
  3. Rear end whine, who's got it?
    By Eagle in forum Drivetrain
    Last Post: 11-01-2007, 06:53 PM
  4. Rear End Whine
    By Blackout01 in forum Drivetrain
    Last Post: 07-21-2007, 08:35 AM
  5. Rear end whine??
    By speedydog in forum General Help
    Last Post: 04-12-2007, 04:45 PM
