    Arkansas
    99 Trans Am
    Inline Fuel Pump question
    Ok I want to buy a walbro inline fuel pump that says it supports applications upward of 600rwhp. My question is how does this work in conjunction with your stock pump? Will the stock pump also need modification? I was thinking about buying the hardwire kit for the fuel pump since that will boost pressure. Would I benefit more if I stuck that on the stock up and let the inline just do its job? This question was brought to my attention on the nitrous forum and I had never really thought about it prior to that. Any info wouldbe appreciated. thanks
    Member Transam388's Avatar
    Cypress, TX
    98 Trans AM
    I always question this as well. How does a higher output pump work with the stock pump in front of it. If the stock can only push so much out then isn't the second pump going to be held back by the first.?
    From what I have heard and it make sense though is that it is better to get a new in tank high output pump. The pumps use the gas to help cool them whereas an external will get hotter and probably die sooner.
    98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
    Arkansas
    99 Trans Am
    hopefully someone will have some input
    Arkansas
    99 Trans Am
    So I guess I have an answer for my own question now. From what I have been told the AMOUNT of fuel is never the issue, just the amount of pressure that the pump can build. A guy used the example for me. Its like a water hose, the water can always flow through it but the pressure might not me good enough to do anything with but if you through a pump in there to help the same amount of water build pressure then it can use the same amount of water but get there much faster and with more pressure. The inline just pretty much ensures that the pressure never drops below a safe level and the stocker has more than enough capability to just let fuel flow.
    Member danziger's Avatar
    Aug 2006
    Chesapeake, VA
    Le Mans Blue
    2004 Z16
    The inline is just a "booster" to keep fuel pressure from dropping. You pretty much answered your own question above.
    A bigger in-tank pump would be best, but a inline is cheap insurance with the nitrous. I have an inline-pump and it works great. It will make some noise, though, so see if you can get a sound-bite first.
    Earth
    yeah, I have the Zex fuel pump boost. It adds to the initial whir when the pressure is primed up but I never hear it after that. Hope it really does what I paid the money for.
  1. fuel pump question
    By ajonesz28 in forum General Help
    Last Post: 05-14-2009, 09:34 AM
  2. Fuel pump and inline boosters
    By grandkodiak in forum LT1
    Last Post: 07-26-2007, 10:41 AM
  3. Inline Fuel Pump
    By fastbuff in forum General Help
    Last Post: 12-11-2006, 01:09 PM
  4. Walbro inline fuel pump
    By unleashed in forum External Engine
    Last Post: 04-03-2006, 11:56 AM
  5. Inline fuel pumps
    By FastRegalWE2 in forum Nitrous
    Last Post: 09-20-2005, 06:01 PM
