Thread: Inline Fuel Pump
12-06-2006, 10:10 AM #1Junior Member
- Oct 2006
- miami
Blue- formula 98
Inline Fuel Pump
I have a 98 LS1 and I was able to get an Inline Fuel Pump made by MSD if i install this on my daily driver car will this affect the Intank Fuel pump cuz i dont want to mess that one up i know its expencive i need help i want to know if i should install it or not thanks
12-06-2006, 10:10 AM #2Blown, Stroked, & Sprayed
- Aug 1999
- No Where
An intank would be better.
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
12-07-2006, 09:04 AM #3
First off I would look at the case of "Do you really need it"? How much HP are you pushing? 10 to 1 your stock in tank pump is fine. If you are concerned, first put a fuel pressure tester on the fuel rail and see what it is producing in PSI. Normally a stock 98 should be at roughly 58 PSI. Unless you are seeing the PSI dropping I would not mess with it.
98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
12-11-2006, 01:09 PM #4
Why do you want to install it? Is your current fuel pump shot? Are you running a big shot of nitrous? If installed correctly, there will be no adverse effects on your regular pump. I have an inline and it is noisy, but effective for my power level...
Adding a secondary, inline fuel check valve to 2002 ws6
By awoodby in forum External EngineReplies: 10Last Post: 10-02-2015, 09:48 AM -
Fuel pump and inline boosters
By grandkodiak in forum LT1Replies: 3Last Post: 07-26-2007, 10:41 AM -
Inline Fuel Pump question
By juiced99ws6 in forum General HelpReplies: 5Last Post: 03-04-2007, 07:15 AM -
Walbro inline fuel pump
By unleashed in forum External EngineReplies: 1Last Post: 04-03-2006, 11:56 AM -
Inline fuel pumps
By FastRegalWE2 in forum NitrousReplies: 1Last Post: 09-20-2005, 06:01 PM
