Thread: torx screws?
    Feb 2007
    dfw, texas
    silver, black
    01 vette, 95 t/a
    torx screws?
    has anyone here had any trouble removing the torx screws on top of their drivers side shock mounts? i can't get mine out. i've gone through a couple of bits already and got some stronger ones, and those want to strip out the screws. i hate these things! i have an impact driver, but they still won't budge. if i ever get these things out, i'm putting something else back in. any suggestions?
    Feb 2007
    dfw, texas
    silver, black
    01 vette, 95 t/a
    '95 t/a
    the car is a '95 t/a btw.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    can't say i ever have. then again, i use an impact gun to do it with.
    Feb 2007
    dfw, texas
    silver, black
    01 vette, 95 t/a
    these bolts stipped one of my impact torx bits, did i mention i hate these things. i don't know why gm used these things. i'm sure they wanted more clearance for the master cyl. butt damn they could used something better. there's plenty of room to just use the six sided bolts they used on the other side.
    Earth
    If the bolt heads are already damaged and you are having no luck with the torx bits (wondering if you used the correct size) then you may need to grind the heads off or weld something to them now.
    I know the driver side requires you to move the brake cylinder out of the way to get to them.
    I don't remember now but I may have soaked them with PB Blaster before the job. I realize you're trying to pull the front shock cartridge (struts). Mine where a little tough to get out but nothing like what you are describing. I agree, it is a bad design and can't understand why just two had the torx heads.
    Wait until you pull the strut out and see what the water damage has done to the top of the shock stud. Here's a quick pic of what mine looked like:
    http://i9.tinypic.com/4i45k3r.jpg
    Feb 2007
    dfw, texas
    silver, black
    01 vette, 95 t/a
    damn, thats nasty. i've got the right size, they fit snug as a bug. i'll probably just drill them out. did you put torx heads back in or use something else?
    I used the same bolts as the the rest when I put everything back together.
    This was when I change my springs again I won't even have to loosen the brake master cylinder.
    Feb 2007
    dfw, texas
    silver, black
    01 vette, 95 t/a
    yeah, i just ground off the torx heads, i'll get some normal bolts when it all goes back together, thanx for ya'lls input. should be able to go for a drive after the daytona 500. well maybe, the car is old and there may be more stuck crap.
  1. Part Numbers for Air Box Screws
    By Prime117 in forum External Engine
    Last Post: 08-15-2015, 05:09 AM
  2. torx bolt on the a/c pulley
    By redbird555 in forum General Help
    Last Post: 06-19-2010, 04:18 PM
  3. WS6 Trunk screws...
    By jon-v8 in forum Firebird / WS6
    Last Post: 04-16-2009, 07:07 AM
  4. Tubes and screws?
    By Hot Black Trans-Am in forum Wheels and Tires
    Last Post: 07-28-2008, 02:44 PM
