    May 2015
    NY
    2002 Trans Am WS6
    Part Numbers for Air Box Screws
    Would anyone know of the part numbers for the 4 screws and washers that hold the lower air box assembly on the Trans Am WS6? Mine are rusted and I would like to replace them.
    Thanks
    Chris
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by Prime117 View Post
    Thanks
    Chris
    The washers come with the screws, but I would't recommend buying them from GM. The replacment peices are a black screw/washer that rusts out even faster than the originals, ask me how I know
    Personally, I am going to go find some stainless screws/washers and use those instead.
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Just take your current rusted bolts into a local parts store like pep boys, napa, auto zone, etc. They normally have a rack of nuts and bolts that should fix ya up. Make sure to get stainless steel so they will never rust out again.
    1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    You can also go to your local hardware store - they'll likely have more options and be cheaper (Menards, Loews, Home Depot, Ace Hardware, etc).
    May 2015
    NY
    2002 Trans Am WS6
    Thanks Guys,
    Everything I find at Lowes/Home Depot seem to be the right size, except they do not seem to thread right.
    I also found them on yofab.com if anyone else has trouble finding them.
    Chris
  1. I need Part numbers
    By Spikito in forum Camaro / SS
    Last Post: 07-07-2009, 03:47 AM
  2. gm part numbers
    By keving711556 in forum Manual Transmission
    Last Post: 10-12-2008, 04:55 PM
  3. Question: Part number for door screws
    By ras2247 in forum General Help
    Last Post: 06-19-2008, 11:28 AM
  4. Part number for factory amp screws...
    Last Post: 06-01-2008, 04:20 AM
  5. GM Part Numbers
    By phoff in forum General Help
    Last Post: 04-22-2006, 03:54 PM
