Thread: Tubes and screws?
07-25-2008, 05:26 PM #1
- Mar 2006
- WI
- Blog Entries
- 1
Tubes and screws?
If your running tube type drag racing tires do need to use screws? I'm looking at 26x11.5x16 ET Streets. I'm on stock power other than a cat back yet, but I have no idea if tube type tires spin on the rims easier or not.
My other thought was going tubeless with the ET street radials 295/50-16 to keep it simple, but I might need to swap my rear springs before I can run a 27.5" tall tire so I may go for the 255/50-16.
Any other recommendations welcome. I'll only be running the tires at the track seeing my nearest track is about a 2 hour drive from me.
07-25-2008, 06:52 PM #2
- Jun 2002
- Montreal, CANADA
only once you start getting into serious power will you need the screws.
stock-ish power levels, I don't see the need.Eugenio_SS
07-25-2008, 07:01 PM #3
- Mar 2006
- WI
- Blog Entries
- 1
Thanks, I'm leaning towards trying the tube tires then. Sounds like they get better traction and should fit better. I'm going to take a run with my street tires being only 25.5 and see where my rpm's are at. Hopefully I'll get the new rear installed this weekend!
07-25-2008, 08:16 PM #4
I've always ran ET Streets tubeless, never had an issue. Many 10 sec passes and tons of other passes with 1.40 60'. My Dad's car was a H/C Firehawk and it had tubes in the et streets, but w/o screws. It would spin the tire/tube some and the valve stem would be slanted and pulled. So if you go tube, might wanna screw if you start making power. Otherwise don't worry about the hassle.
ChrisLoving Memory:Tim Huddleston "HOTHAWK" Great Father and my Best Friend
07-26-2008, 05:44 AM #5
if you tube it scrue it just i case. you sholdnt need the et steets on just stock power and thay dont last long at all. have you looked at the mt drag radil thay last longer and hock real good.
07-26-2008, 06:04 PM #6
screws are only needed if you are spinning the tire on the wheel. i doubt you'll ever run into that. i haven't.
07-28-2008, 02:44 PM #7
- Mar 2006
- WI
- Blog Entries
- 1
Thanks for all the replies. I'll try screw less first and see what happens. I guess I still have to figure out how tall of tires I want to run anyway.
WS6 Trunk screws...
By jon-v8 in forum Firebird / WS6Replies: 8Last Post: 04-16-2009, 07:07 AM -
Opti Spark Screws
By camarostripes96 in forum LT1Replies: 6Last Post: 10-27-2007, 03:37 PM -
torx screws?
By divinezx9 in forum Suspension and HandlingReplies: 7Last Post: 02-18-2007, 07:53 AM -
26x11.5x16 ET Streets on TA wheels with tubes and screws
By striker754 in forum Parts For Sale / TradeReplies: 8Last Post: 08-20-2006, 06:50 PM
