Results 1 to 3 of 3
    Member jimmy77611's Avatar
    Feb 2007
    Here
    2000 Z28
    Can't disconnect hose at trans.
    I'm trying to change my clutch master cylinder, and I can't get the line disconnected from the trans. I've pushed the white clip all the way flush with the slave cylinder hole, but it still won't pull out. I'm at my whits end! Also, what size is the bleeder screw above the line. Thanks.
    Earth
    There's a line disconnect tool available - if you haven't already used it. It is simply a fork that slips into the groove that releases the connector. The only one they had at the time at AutoZone rental ($5) was one for a ford. It fit a little tight but still worked easily.
    As for the bleeder, I've not had to use it but 10 mm is what I would first think.
    Feb 2007
    Here
    2000 Z28
    I finally got it loose. Had to push in on the hose a little, push the white clip flush and then into the groove a little all the way around. Then pulled, and it came out. Install university said to push the clip and it would pop out, mine did not. The bleeder screw was a 12mm.
  1. Trans Am WS6 Seat Lumbar hose
    By aerojt in forum Firebird / WS6
    Last Post: 02-08-2016, 03:51 PM
  2. I cant disconnect the fuel line
    By freddy_caprice in forum External Engine
    Last Post: 06-09-2011, 09:49 AM
  3. Help: Can't get quick disconnect in slave cy!!!
    By z28tito in forum Manual Transmission
    Last Post: 12-13-2009, 07:56 AM
  4. EGR AIR disconnect
    By roadracetransam in forum External Engine
    Last Post: 03-07-2006, 07:58 AM
  5. EGR AIR disconnect
    Last Post: 03-06-2006, 11:50 PM
