Results 1 to 3 of 3
Thread: EGR AIR disconnect
03-06-2006, 11:52 PM #1
EGR AIR disconnect
I no longer use my car for street use. I am interested in putting a new exaust on the car, headers into x-pipe into mufflers into turndown in front of rear differential. Getting rid of the EGR valve, as well as the whole AIR pump and hose assembelly, plus the cats. Am I going to get a SES light, and will the ECM (computer) force the engine to run like crap, to compensate for a "malfunctioning" emission system?
Any experiance with eliminating emission systems. Any benefits, other than unclutering the engine bay, and getting rid of about 30 lb's?
03-07-2006, 05:30 AM #2Member
- Northern Virginia
BLACK- 2000 Camaro SS
Yes, you will set the SES light, especially from removal of the EGR. (Some have removed just the AIR w/o setting codes at all, or only intermittently) The codes that are set won't affect how the engine runs, however. You pretty much have the benefits covered.
03-07-2006, 07:58 AM #3
In reference to the first question i was wandering if anybody had or could find a breakdown on installing non emissions headers on cars equiped with egr and air. I am having trouble understanding how to remove the T-valve on top of the intake where all three air pump hoses come together. It has a small sorce of vaccum to it and im not shore how or where to block it off at or if it even matters.
I cant disconnect the fuel line
By freddy_caprice in forum External EngineReplies: 7Last Post: 06-09-2011, 09:49 AM -
Help: Can't get quick disconnect in slave cy!!!
By z28tito in forum Manual TransmissionReplies: 1Last Post: 12-13-2009, 07:56 AM -
How do you disconnect the Fuel Rails off..
By OnEbAdReDSS in forum External EngineReplies: 4Last Post: 11-09-2008, 09:06 AM -
Can't disconnect hose at trans.
By jimmy77611 in forum Manual TransmissionReplies: 2Last Post: 02-18-2007, 11:31 AM -
EGR AIR disconnect
By roadracetransam in forum External EngineReplies: 0Last Post: 03-06-2006, 11:50 PM
