Results 1 to 2 of 2
12-12-2009, 05:17 PM #1Junior Member
- Mar 2006
- San Diego, Ca
pewter- 1999 Z28
Can't get quick disconnect in slave cy!!!
I've changed my clutch twice with no issues until now. After all the hard stuff is done and over for some reason I can't get the freaking line back in the slave cylinder. Never had this poblem before but seem like the white coulpling will only go in so far preventing the line from connecting. To make matters worse I slighty damaged the top edge of the white coupling trying to push it back in with the screwdrivers. Anyone have this problem in the past?? Can you get a replacement coupling without having to buy an entire master cylinder?? Seems like one of the easist parts of the jobs but right now it's killing me !!!
12-13-2009, 07:56 AM #2Senior Member
- Apr 2008
- Madison, WI
I've heard of this, I think there is hydraulic pressure buildup in the slave thats fighting against you. open the bleeder on the slave, then try to connect it.
Help: Master cylinder quick disconnect
By Pitchlock in forum Manual TransmissionReplies: 2Last Post: 01-02-2013, 04:32 PM -
QUICK HELP! Slave cyl questions
By jtramo in forum General HelpReplies: 0Last Post: 11-24-2006, 10:51 AM -
EGR AIR disconnect
By roadracetransam in forum External EngineReplies: 2Last Post: 03-07-2006, 07:58 AM -
EGR AIR disconnect
By roadracetransam in forum External EngineReplies: 0Last Post: 03-06-2006, 11:50 PM -
Clutch slave line disconnect tool J 36221
By boodyman in forum Manual TransmissionReplies: 6Last Post: 01-29-2006, 04:06 PM
