09-28-2005, 12:58 PM #1boodymanGuest
Clutch slave line disconnect tool J 36221
What's the trick to getting that "white clip" manipulated such that the master to slave clutch line will fiannly come apart? Used the search function and can't get any threads I can read. New to this forum..I'm working on a '99 vette trying to change the M/C to the McLeod adjustable. How does that white ring work? Does it depress back inside the larger barrel half? HELP!
Bill
09-29-2005, 12:02 AM #2
Got this off of the drill mod thread-should answer your questions.It's telling you to push in the white ring -it's a quick disconnect-then the line should release-go look at the pictures and you should be able to figure it out. http://www.installuniversity.com/ins...r_cylinder.htm well it's supposed to take you there-go to the "what is a drill mod" thread if you can't find it.
09-29-2005, 04:15 AM #3boodymanGuest
got it loose, thanks!
01-29-2006, 01:04 PM #4Junior Member
- Nov 2005
How far in does it go? I've pushed it in as much as I can and the line is still not coming out!!!
01-29-2006, 01:10 PM #5
if the ring is pushed in all the way-then work the lines together also and then it should slide apart.sometimes pushing the lines together with the ring pushed in will do the trick,a little penetrating oil can help too.
01-29-2006, 01:18 PM #6Junior Member
- Nov 2005
thanks 02z28ls1! What do you mean by working the lines together?
It turns out I had to push the ring in even further so that I could barely see it before it came off. It's overcast today so taking a flashlight down there helped.Last edited by NewSS; 01-29-2006 at 03:03 PM.
01-29-2006, 04:06 PM #7
Well alot of these fuel lines that are quick disconnects like that need to be pushed together before they release so you can pull them apart.It's hard to describe but once you've done it you'll know what I mean.
clutch line from master to slave 98-02 fbody
By robs98mysticZ in forum Parts Wanted / TradeReplies: 0Last Post: 10-12-2014, 07:19 AM -
I cant disconnect the fuel line
By freddy_caprice in forum External EngineReplies: 7Last Post: 06-09-2011, 09:49 AM -
Hydraulic Clutch Line Remover Tool
By SuperSport346 in forum ToolsReplies: 6Last Post: 02-11-2010, 04:41 PM -
Help: Can't get quick disconnect in slave cy!!!
By z28tito in forum Manual TransmissionReplies: 1Last Post: 12-13-2009, 07:56 AM -
Needing clutch master cylinder, line and slave...anyone help?
By Dat240zg in forum GTOReplies: 0Last Post: 01-05-2007, 01:33 PM
