    Georgia
    2014 Camaro 1LS
    problem- a4 shifting hard into 1st gear
    My car starting do this last week when it was 16 degrees outside. Its an a-4 and when I started down the road when it would change into the first gear it would shift hard not smooth. Did it all the way to work but only when shifting the first time from take-off all other gears were smooth. Later that day when I left work and it had warmed up outside it was fine. It didnt do it again until today. I dont know if being cold would have any effect on it but was wondering if anybody else has had this problem before ?
    Member Bandit1's Avatar
    Philly PA
    2002 TA WS7
    its from bring cold out mine does it to in the really cold weather fine when the car warms up
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by Bandit1 View Post
    how long has yours did it ?
    Philly PA
    2002 TA WS7
    since i had the car and i had 3 V6 fbodys that did the same thing
    Georgia
    2014 Camaro 1LS
    this is my first winter with mine
    Philly PA
    2002 TA WS7
    try letting the car warm up to opperating temp before u drive it when its really cold out i warm the car up and then drive it
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    thicker fluid makes for more pressure.
    Georgia
    2014 Camaro 1LS
    ok i was kinda worried i tore something up doing a burnout lol
  1. hard shifting and reverse pops out
    By evil_goat in forum GTO
    Last Post: 07-14-2009, 10:00 AM
  2. Hard noise when shifting gears
    By DesertRat in forum Drivetrain
    Last Post: 05-26-2009, 06:23 PM
  3. Hard time shifting(sometimes)
    By Aetos in forum Manual Transmission
    Last Post: 07-12-2008, 07:08 PM
  4. problem-a4 shifting hard to first gear when cold
    By Speedy_Gonzales in forum Automatic Transmission
    Last Post: 02-03-2007, 04:04 PM
  5. shifting hard
    By snaggeltooth in forum Automatic Transmission
    Last Post: 06-23-2006, 01:17 PM
