Thread: shifting hard
    alabama
    Gray
    2012 Challenger R/T
    shifting hard
    I have 97 T/A with 72k miles on her. I just went for like 45 min drive. Everyhing was shifting just fine. Then I got back into traffic with stop lights and Wow. Everytime I started from a complete stop the car would shift so hard it made the tires chirp. This is just like shifting in stop and go traffic. Then my SES light came on.Fluid is ok . Any thoughts..
    alabama
    Gray
    2012 Challenger R/T
    shows code p1870 ???
    Senior Member
    Jacksonville, FL
    Doesn't sound good - P1870 is Transmission Component Slipping. Maybe something in this link will help: www.ls2.com/boggs/a4/DTC%20P1870%205.8.htm The DTC is maximizing your line pressure.
    alabama
    Gray
    2012 Challenger R/T
    http://www.cariq.com/Vehicle_Diagnos...=expanded&sb=5
    answered my own question , but might be something other should know
    alabama
    Gray
    2012 Challenger R/T
    here is the thing about our trans. They are to smart for there own good. What happens is a gear starts to slip, the computer tries to fix it. Then the problem is one gear is slipping , but the computer has to address it to all the gears. Short answer , if your tranny does anything weird or shifts hard when hot.......TAKE IT IN ASAP...or better yet have it run at a trans shop even if it is acting ok...IMO....
    Jun 2006
    GA
    Maroon
    86 Trans Am
    it sounds like a valve body problem to me
    Email Me And Ill Send You Instructions To Fix This
    Without Removing The Valve Body Only The Pan And Five Minutes Or Less And Your Fixed
    Megamax
    alabama
    Gray
    2012 Challenger R/T
    actually mine was far worse than that . someone had been into it and done all sorts of crazy things. I was saying when you trans starts acting up have it looked at , right then...
  1. hard shifting and reverse pops out
    By evil_goat in forum GTO
    Last Post: 07-14-2009, 10:00 AM
  2. Hard noise when shifting gears
    By DesertRat in forum Drivetrain
    Last Post: 05-26-2009, 06:23 PM
  3. Hard time shifting(sometimes)
    By Aetos in forum Manual Transmission
    Last Post: 07-12-2008, 07:08 PM
  4. problem- a4 shifting hard into 1st gear
    By Speedy_Gonzales in forum Automatic Transmission
    Last Post: 02-03-2007, 07:20 PM
  5. Trans Shifting Hard and Burning Fluid
    By wcfarrell in forum Western Members
    Last Post: 06-27-2006, 07:36 AM
