    suckme sideways andrew69_04's Avatar
    nebraska
    black w/ ghost stripes
    02 ws6
    Stiff Shifter???
    i have a 2000 WS6 and im not sure where to even start on this shifter. the car runs fine, clutch is good, clutchmaster cyl might need replaced but thats besides the point. when the car is off or running, the shifter is in neutral and the shifter is really stiff. its easy to get to 1-2 gear. 3-4 isnt to hard. but pushing it over to 5-6 and Reverse is a bitch. it will go into the gear and they work fine its just so tight. my 02 is nice and smooth and so is my 99 so i have no idea whats going on. the car is all stock so im not sure if something is bad or whats up. any suggestions????
    Member ApexVIII's Avatar
    Modesto, CA
    1998 Camaro Z28
    mine is just like that any ideas??
    M6, Lid, Ported and Polished Throttle Body (By Me!), LT, Custom Catted Y, Electric Cutout, PHB, LCA13.21@108 with a 2.3 60'
    metro Detroit area
    Pull shifter and look at the plastic socket it sits in. I bet it is loose. Relpace it. Be sure to epoxy it in place. You will have to buy a T5 part because the T56 is only sold bonded to the offset lever( more $) which is a little more difficult to change.
    Modesto, CA
    1998 Camaro Z28
    Quote Originally Posted by 30thbird View Post
    if its loose then its hard to shift? cuz mine is loose i looked at it
    Modesto, CA
    1998 Camaro Z28
    any one?
  1. 98 WS6 brakes are very stiff........
    Last Post: 04-25-2016, 08:02 AM
  2. a/c on= stiff clutch pedal?
    By Ramairgod84 in forum General Help
    Last Post: 07-17-2010, 05:57 PM
  3. stiff clutch
    By Z28_SS in forum Manual Transmission
    Last Post: 06-27-2007, 07:30 PM
  4. too stiff for it's own good?
    By third_shift|studios in forum Suspension and Handling
    Last Post: 08-21-2006, 01:23 AM
  5. Stiff clutch
    By eldoradocanyon in forum Manual Transmission
    Last Post: 03-28-2006, 06:49 PM
