04-23-2016, 12:58 PM #1Senior Member
- Detroit
Black/Red/Black/Red- 98WS6/06MCSS/86GN/06H3
98 WS6 brakes are very stiff........
I just had new rotors and bads installed, the has kinds been a issue since i got the car. You have to apply more pressure than usual to hold the car at a stop and to slow down. Any ideas???????Brake Booster ????????
04-23-2016, 01:41 PM #2
04-23-2016, 02:08 PM #3Senior Member
- Detroit
04-24-2016, 01:31 PM #4
First solution is always to rebleed the entire system. You can get air in the master cylinder as well as at the calipers. If a full rebleed doesn't solve the problem then I would have a competent shop check the pressure after the master cylinder, and after the ABS pump. Master, booster, or abs pump can cause you problems. You'll just have to isolate where the pressure either is not at the correct spec or is leaking down instead of holding. Much better to pay for proper testing than to start throwing new parts at it hoping that you'll get lucky.
04-25-2016, 06:16 AM #5Spaz is My Mentor
I'd check the vacuum hose 1st for cracks or if even connected then bleed the brakes.
04-25-2016, 08:02 AM #6Exalted Cyclops
- Feb 2007
- San Diego, CA
If none of the above works then try checking the wheel sensors. One of mine on the rear axle went bad (grease fouled or some such) on the 02 and it felt like a stiff pedal...
67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
New tranny mount (stiff)
By doberman 152 in forum General HelpReplies: 6Last Post: 06-04-2008, 07:49 AM -
Stiff Shifter???
By andrew69_04 in forum Manual TransmissionReplies: 4Last Post: 11-13-2007, 01:50 PM -
stiff clutch
By Z28_SS in forum Manual TransmissionReplies: 25Last Post: 06-27-2007, 07:30 PM -
too stiff for it's own good?
By third_shift|studios in forum Suspension and HandlingReplies: 13Last Post: 08-21-2006, 01:23 AM -
Stiff clutch
By eldoradocanyon in forum Manual TransmissionReplies: 10Last Post: 03-28-2006, 06:49 PM
