Results 1 to 14 of 14
Thread: too stiff for it's own good?
08-15-2006, 07:53 AM #1Detailing + Design
- Pittsburgh, PA
Is there a possibility that our cars can be made too stiff for doing twisties and stuff? I'm wondering b/c right now i have Koni's on level 1, a tq arm, LCA's and a 35mm sway bar.
I was driving on a dry road and took a turn around a bend and felt the rear start to loose it abit [yes i was trying to accelerate into it]. So i eased off through the next few turns as i thought to myself "i'm soon to add SFC's and a strut tower brace...will that be over kill? will my car be too stiff and want to spin out b/c it has no give?"
would a stiffer front setting and looser rear setting be a better combo?
Custom Car Emblems from third_shift|studios
jaison tortorea
08-15-2006, 08:44 AM #2
08-15-2006, 08:53 AM #3M6 King
- Mar 2006
- WI
- Blog Entries
- 1
Do you have good wide tires on it? Are they over inflated? How big is the rear sway bar? Maybe that right foot was just planted a little heavier than you thought. Stiffer up front might help a bit. I don't think SFC's and a STB would hurt anything. If the rear is too stiff it'll skip around some and could cause you to spin.
08-15-2006, 09:11 AM #4Detailing + Design
- Pittsburgh, PA
i have a stock rear sway. My tires are also getting bald, can anyone recommend a good road tire? I currently have Firestone Fuzion Zr1's and they've lasted me a good 40K miles
08-15-2006, 09:23 AM #5
08-15-2006, 09:55 AM #6Detailing + Design
- Pittsburgh, PA
how long have those lasted you?
08-15-2006, 10:24 AM #7
08-15-2006, 12:54 PM #8Detailing + Design
- Pittsburgh, PA
i found a set on Tiresavings.com for $86!
08-15-2006, 12:55 PM #9Senior Member
- Aug 2001
- San Diego, CA
383 w/Meth & ProCharger- 2001 Camaro Z28
Sounds to me like the problem with your car is between the pedals and the seat.
My point is you need to slow down for entry into a turn, get it to turn, then accelerate off. (Car control) Slower is better when it comes to entering a turn. This is where you have to learn your car. How it reacts at different speeds into and out of turns. Learn that so you can make the most of what you have, not forcing it to do something it or you can't do. Also remember your car is around 3500 lbs!! It's gonna feel sluggish and less responsive than a go-kart or sports car(corvette).
Chat with the moderators about your suspension and what you want to do with your car.
Just my .02
08-15-2006, 12:58 PM #10Senior Member
- Aug 2001
- San Diego, CA
Until you learn what your car is doing will you be able to figure out if the car pushes (too tight) through a turn. But first you need to learn what tight and loose feels like.
I hope this doesn't come across as condescending or anything, just laying out the facts.Last edited by ntimid8r; 08-15-2006 at 01:43 PM.
08-15-2006, 01:44 PM #11Crazy Canuck !
- Jun 2002
- Montreal, CANADA
SFC will help.
you mention you have 35mm front swaybar... what's the rear one ?Eugenio_SS
08-15-2006, 02:26 PM #12
08-20-2006, 09:52 AM #13Member
- Buffalo
I think it's very possible you can have it too stiff. I was parking my car last month at a restaraunt and the back parking lot has a big dip in the road as you enter the lot. So I wanted to approach it at an angle. After the dip the road it was also inclined a little bit. So it was trying to put a flex on the body of my car. And this sounds weird, but when my back tire was going through the dip, it lost traction. There was a little bit of gravel on the paved surface but it still wouldnt go up the slight incline which was immediately after the dip in the road. So, it was totally weird. I think if my car didnt have 35" anti-sway bars and lower springs and a STB, it would have done just fine.
08-21-2006, 01:23 AM #14Member
- South of Heaven
Navy Blue Metallic (NBM)- 2002 Camaro SS
Actually one of the most critical components of handling is your tires. You could have the SFC/STB/APHR/ALCA/35mm/25mm/ATA/Springs/Shocks and still handle terribly if you are touching pavement with Pep Boys special $59 bicycle tires...
98 WS6 brakes are very stiff........
By Murder after Midnight in forum Almost Anything GoesReplies: 5Last Post: 04-25-2016, 08:02 AM -
a/c on= stiff clutch pedal?
By Ramairgod84 in forum General HelpReplies: 4Last Post: 07-17-2010, 05:57 PM -
Stiff Shifter???
By andrew69_04 in forum Manual TransmissionReplies: 4Last Post: 11-13-2007, 01:50 PM -
stiff clutch
By Z28_SS in forum Manual TransmissionReplies: 25Last Post: 06-27-2007, 07:30 PM -
Stiff clutch
By eldoradocanyon in forum Manual TransmissionReplies: 10Last Post: 03-28-2006, 06:49 PM
