Results 1 to 3 of 3
Thread: finally solved!
    Lewiston, Idaho
    73 Z28
    finally solved!
    I first encountered this clutch problem back in November. It would refuse to disengage all the way, sometimes. It would work for 5 days then act up for 3more. We bled the clutch with the special gizmo, it worked for 2 weeks, Pontiac changed the juice in the tranny, it worked for almost 2 weeks. Got so I could tell when it was going south as it would get harder and harder to shift. It would be bad for one day and not the next, sometimes it would act up and clear up on the same run.
    Finally Pontiac tore into it and discovered a 1/4 inch long roller bearing the "size of a pencil" embedded in the disc. They said it had been bouncing around in there for some time before it had stuck.
    All's well now and I still love that car!
    01 WS6 Pewter
    Feb 2006
    2002 WS6
    If it was stuck to the clutch disk I would suggest a replacing the clutch and a resuface of the pressure plate if it wasn't done already.
    Lewiston, Idaho
    73 Z28
    Yep, replaced everything!
  1. LS1 Miss Solved
    By Teeeman in forum Almost Anything Goes
    Last Post: 06-10-2010, 02:38 PM
  2. GM's problems are solved...
    By Packy in forum Almost Anything Goes
    Last Post: 04-15-2010, 04:15 PM
  3. O2 Problem Solved
    By JeremyRay in forum Firebird / WS6
    Last Post: 11-14-2007, 02:12 AM
  4. hesatation problem finally solved
    By drdon51 in forum General Help
    Last Post: 08-07-2006, 09:54 PM
  5. Problem maybe solved
    By wc00ac in forum LT1
    Last Post: 09-11-2005, 10:55 AM
