Results 1 to 2 of 2
    Central Texas
    Problem maybe solved
    Well as you know I have been having idle issues and car wouldn't stay running well I unpluged my O2 sensors and now she idles fine and doesn't cut out and die. She has be running for about 50 minutes now.
    Central PA, USA
    1995 Trans Am 6 Speed
    My two cents. Unplugging the O2 will put the PCM into "limp home mode" which is run rich. Don't know your original problem. But, try reconnecting and see if it did what it did before. Give time for the O2 to warm to operating temps.
    Of course, head to the local Advance Auto or Auto Zone for a replacement O2. They both offer free use of the O2 replacement tool with a deposit.
    Good luck.
  1. Spec Problem SOLVED!!
    By Edward-T in forum Manual Transmission
    Last Post: 12-13-2011, 04:22 AM
  2. Tapping noise from valvetrain - problem solved!
    By DaddySS in forum Internal Engine
    Last Post: 02-25-2008, 11:04 AM
  3. O2 Problem Solved
    By JeremyRay in forum Firebird / WS6
    Last Post: 11-14-2007, 02:12 AM
  4. hesatation problem finally solved
    By drdon51 in forum General Help
    Last Post: 08-07-2006, 09:54 PM
  5. STS problem solved..sort of
    By kllrvet in forum Forced Induction
    Last Post: 03-18-2006, 07:25 PM
