Results 1 to 13 of 13
Thread: tranny dip stick hard to get out
01-23-2007, 02:17 PM #1
Does anyone have this problem ? Dip stick is an sob to get out. Is ther some trick to unlock it ? I have to get some pliers a hold of it to get it out. Once I get it started it comes out easy. Also should the stick be flat all the way down or have a twist in it toward the base ?
01-23-2007, 03:30 PM #2
Are you releasing the handle first?
Sometimes they are a SOB to get out. Probly normal.
01-23-2007, 03:33 PM #3
01-23-2007, 03:39 PM #4
Try putting it in upside down.
01-23-2007, 03:40 PM #5
01-23-2007, 03:43 PM #6
Sometimes you gotta turn em sometimes you don't. Not sure unless I tried it.
01-26-2007, 02:18 PM #7
I have this same problem. Just hit it with a small amount of wd-40 and it'll come right out. Mines been a pain to get out since day one. Now I don't even try it without hitting it with wd40 first.
01-26-2007, 02:23 PM #8
01-26-2007, 03:05 PM #9
It's been a while since I had it out but I'm 99.99999999% sure that it twists also.
01-26-2007, 04:38 PM #10
01-26-2007, 04:50 PM #11Just me
- Nov 2006
- Broken Arrow, OK
They have always been difficult to remove. Its possible that the tube is putting it in a bind and might need to be moved around some. That has helped me a few times in the past to get the dipstick out easier.
01-26-2007, 05:40 PM #12
01-26-2007, 07:06 PM #13Just me
- Nov 2006
- Broken Arrow, OK
I think it has a twist in it, but I am not 100% positive on that.
Hard up/downshift in 2nd....shift kit/bad tranny?
By ggino85 in forum Automatic TransmissionReplies: 2Last Post: 02-26-2010, 02:45 PM -
Tranny shifts hard during WOT
By Anwazi in forum Automatic TransmissionReplies: 3Last Post: 04-23-2008, 11:11 AM -
Noise under hard acceleration-auto tranny related
By Zapper2003 in forum General HelpReplies: 3Last Post: 03-14-2008, 05:31 PM -
WTB tranny cooler, Trans Dip stick tube...
By jwitt2 in forum Parts Wanted / TradeReplies: 0Last Post: 06-04-2007, 11:59 AM -
Manual Tranny Stick Noise?
By Sunset T/A in forum Manual TransmissionReplies: 3Last Post: 09-19-2006, 03:23 PM
