Thread: Manual Tranny Stick Noise?
09-18-2006, 01:37 PM #1
Having noise coming from stick after a missed shift 2nd to 1st instead of 2nd to 3rd. Did this damage the plastic isolator bushing only or what else could have got damaged internally?
09-19-2006, 07:09 AM #2Member
- metro Detroit area
If you missed the shift did it clash? If you actually got 1st( very possible) the noise you hear is most likely bent pushrods from over-speed.
09-19-2006, 02:49 PM #3
About 40 mph. If it was bent push rods, why is the vibration noise in the tranny stick. NO gear grind, just a hard clunk, ann slow down.
2002 Sunset Orange TransAm 6 spd.
http://www.mustangmods.com/data/1327/dadsigpic2.jpg
09-19-2006, 03:23 PM #4
Well at least you didn't over-rev the engine or transmission input shaft, 1st gear is good to 50MPH assuming you have stock 3.42 gears.
However, it definitely sounds like something broke, did you let the clutch out in 1st or just engage it??
It could be a lot of different things, heres a link to the T56 Service Manual with troubleshooting information:
http://www.ttcautomotive.com/English...ice_Manual.pdf
Help: Shifting stick moves in manual car?
By Ls1_385hp_T/A in forum General HelpReplies: 8Last Post: 05-16-2011, 09:23 PM -
short stick shift noise??
By DMAN in forum General HelpReplies: 2Last Post: 10-13-2010, 06:04 PM -
Help: Stuck Manual Tranny
By fish in forum Manual TransmissionReplies: 7Last Post: 04-29-2009, 05:08 PM -
WTB tranny cooler, Trans Dip stick tube...
By jwitt2 in forum Parts Wanted / TradeReplies: 0Last Post: 06-04-2007, 11:59 AM -
tranny dip stick hard to get out
By Speedy_Gonzales in forum External EngineReplies: 12Last Post: 01-26-2007, 07:06 PM
